Maniphest T85261
Eevee AOV passes have inacurate colour and semi-transparent alpha channels that are set to 0.9844 instead of 1
Closed, ResolvedBUG
Philipp Oeser (lichtwerk)
Henry (Shrinks99)
Feb 1 2021, 6:15 AM
  • EEVEE & Viewport
  • BF Blender (2.92)
Henry (Shrinks99)
Jeroen Bakker (jbakker)
Jon Henry M. Faltis 9077149 (295032)
Tokens
"Like" token, awarded by TheShadyColombian.
Operating system: macOS 11.1 / Windows 10
Graphics card: AMD Radeon Pro 5500M 4 GB / GTX 1050ti
Broken: Blender 2.92.0 Beta, February 01, 00:13:03- a9b53daf23ba
Worked: NA
Eevee's AOV passes do not seem to deliver accurate colour or alpha channels when compared to (what should be) equal output from the combined channel. Alpha channels seem to specifically be limited to 0.9844 where they should be 1.
Material setup
Viewing the render of the combined pass (note alpha channel value of 1 at the bottom of the viewer)
Viewing the render of the cube pass (note alpha channel value of 0.9844 at the bottom of the viewer)
This has also been noted by this StackExchange user using a ColorRamp instead of an emission shader, this can be replicated with EXRs output from Blender and read into Nuke.
  • Create a new emissive material in Eevee and apply it to an object
  • Use a Shader to RGB node to convert to colour data and attach to the new AOV Output node for Eevee
  • Configure render settings to output as EXR with the "Standard" (linear sRGB) viewer transform
  • Configure render passes to render out the newly created AOV in the View Layer Properties panel
  • Render!
  • Check the values
Blend file is attached!
Revisions and Commits
rB Blender
D10286
Related Objects
Mentioned In
T93601: Eevee AOV passes have inacurate colour
Mentioned Here
rBa9b53daf23ba: Fix T83092: Direction of rotation with View orientation changed in 2.91
Henry (Shrinks99) created this task.Feb 1 2021, 6:15 AM
Henry (Shrinks99) renamed this task from Eevee AOV passes have inacurate colour and alpha channels to Eevee AOV passes have inacurate colour and semi-transparent alpha channels that are set to 0.9844 instead of 1.Feb 1 2021, 6:23 AM
Juan Callejas (TheShadyColombian) awarded a token.Feb 1 2021, 6:30 AM
Henry (Shrinks99) updated the task description.Feb 1 2021, 6:37 AM
Henry (Shrinks99) added a project: EEVEE & Viewport.
Henry (Shrinks99) edited projects, added BF Blender (2.92); removed BF Blender.
Jeroen Bakker (jbakker) added a subscriber: Jeroen Bakker (jbakker).Feb 1 2021, 10:09 AM
Jeroen Bakker (jbakker) added a comment.Feb 1 2021, 10:19 AM
Looks like a missing sample count. (eg divide by 65 samples in stead of 64).
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Feb 2 2021, 9:06 AM
Philipp Oeser (lichtwerk) triaged this task as High priority.
Guess this should be High prio.
Philipp Oeser (lichtwerk) claimed this task.Feb 2 2021, 5:13 PM
Fix incoming.
Jon Henry M. Faltis 9077149 (295032) added a subscriber: Jon Henry M. Faltis 9077149 (295032).Feb 3 2021, 11:54 AM
Philipp Oeser (lichtwerk) closed this task as Resolved by committing rB85fe12071ad7: Fix T85261: Eevee passes have slight inaccurate colors.Feb 3 2021, 3:53 PM
Philipp Oeser (lichtwerk) added a commit: rB85fe12071ad7: Fix T85261: Eevee passes have slight inaccurate colors.
