Maniphest T85364
Bake glossy through Principal BSDF gives the wrong result
Closed, Duplicate
None
Roman (roman13)
Feb 4 2021, 10:38 AM
  • BF Blender
  • Render & Cycles
Germano Cavalcante (mano-wii)
Roman (roman13)
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Bake with Principal BSDF
Worked: Bake with Glossy BSDF
If use Principal BSDF for baking the glossy map produces a result that is not similar to the original texture
Looks like Transmission bake doesn't work either
Open the file and try to bake the glossy map
Related Objects
Roman (roman13) created this task.Feb 4 2021, 10:38 AM
Germano Cavalcante (mano-wii) added a project: Render & Cycles.Feb 5 2021, 9:19 PM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
In fact, there is something limiting what is expected, but I'm not sure if the result is wrong because the color is actually that one (you are requesting the color pass for bake).
Perhaps an intensity pass is missing, or the color must always be mixed with intensity.
Or else specular intensity baking is simply not supported (I personally think this is the case and therefore what we see there is not a bug).
Germano Cavalcante (mano-wii) added a comment.Feb 9 2021, 3:29 PM
This is a known issue and was even discussed in T68925: Baking workflow revamp
Basically the blender's baking system does not include some maps (like specular intensity and roughness).
So it is not a bug but a limitation that, hopefully, will be improved in the near future.
Germano Cavalcante (mano-wii) closed this task as a duplicate of T68925: Baking workflow revamp.Feb 9 2021, 3:29 PM
