Maniphest T85692
knife tool bug
Closed, Archived
None
Ward Duquet (Ceylon)
Feb 16 2021, 12:12 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Graphics card: GeForce RTX 2080 Super with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
When 'Clip start' is below 0.6m the knife tool snaps to the origin and doesn't work anymore.
When you adjust the 'clip start' again above 0.6m the knife tool works properly again.
Related Objects
Ward Duquet (Ceylon) created this task.Feb 16 2021, 12:12 PM
Ward Duquet (Ceylon) updated the task description.Feb 16 2021, 12:20 PM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Feb 16 2021, 2:59 PM
This can depend on the clipping range, yes (also depends on Clip End iirc).
If this is working correctly without the range being unreasonably far stretched, then this is likely the same as T80136: Knife Tool not Working in 2.9 -- and not considered a bug.
To really tell though, you'd need to provide an example .blend file to reproduce.
Philipp Oeser (lichtwerk) closed this task as Archived.Feb 27 2021, 7:11 PM
