Maniphest T86340
Vertex group removing with filter gives unexpected results.
Closed, Duplicate
None
Ruben (rubeste)
Mar 6 2021, 4:37 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Ruben (rubeste)
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.72
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Broken: version: 2.83.12
Worked: Do not know.
When deleting vertex groups while filtering with the search bar it continues down the unfiltered list.
Example:
X
Y
X.001
If you filter for "X" you get this result:
X
X.001
When you delete "X.001" It will select "Y" instead of "X".
1: select the default cube.
2: create these three vertex groups in order:
X
Y
X.001
3: expand the search option in the vertex group section
4: Type "X" in the search box
5: Select "X.001" and press the remove button.
6: You should now notice that nothing is selected. Remove the "X" from the search box to view all vertex groups.
7: You can now see that the "Y" vertex group is selected.
Ruben (rubeste) created this task.Mar 6 2021, 4:37 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Mar 6 2021, 5:09 PM
This is a Known Issue unfortunately and has been reported before, see T76853: UI Lists Filtering can have non-visible items active (e.g. after deletion) which lets you act on non-visible items, will merge these reports.
