Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.09
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Also tested with Blender 2.91.2 and 2.83.12
Addon Information
Name: Wavefront OBJ format (3, 8, 1)
Author: Campbell Barton, Bastien Montagne
Exporting an .obj file with a Principled material that has a Transmission value set is not working as expected. Re-importing the object will automatically set the Transmission parameter back to 0.
According to the documentation Importing & Exporting shader nodes should support the Transmission parameter of the Principled node.
However, the Transmission parameter value does not seem to be included in the export or Blender fails to import the property.
- create an object with a Principled shader node
- set the Transmission parameter to anything else than 0.
- Export the model as .obj and re-import it in a fresh Blender file.
Expected result: The Transmission value is the same as defined before the export.
Actual result: The Transmission value is 0.
