Maniphest T89030
cannot use external cache in particule system
Closed, Duplicate
None
Matthieu (matdem)
Jun 10 2021, 12:04 PM
  • BF Blender
Ankit Meel (ankitm)
Matthieu (matdem)
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: rB84da05a8b806
I want to bake an Emitter particule animation with the option "Disk cache" enabled, so I could use the External storage to run it later.
When I check "external" and select the folder where the bake is, it does not work. Blender detect the points but I have only a single spread of particules emitted, but they last till the end of the animation.
Create new Blender file.
Add a plane.
Add a particule system and set it to "Emitter".
Leave the defaut parameters and go to "Cache" section.
Save the file.
Rename the cache with for example "test".
Select "Disk cache" and then Bake all dynamics.
Once the bake is finished, check "External" and select the folder. *
Check the cache step and run the animation
Matthieu (matdem) created this task.Jun 10 2021, 12:04 PM
Ankit Meel (ankitm) closed this task as a duplicate of T68436: External Particle Cache Playback Is Broken (2.8).Jun 17 2021, 8:00 PM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
