Maniphest T89496
In the Latest Stable Version of Blender 2.93.0 LTS Subdivision surface not working in sometimes and it failed after execution of boolean modifier
Closed, Duplicate
None
Dinesh Nayak (Blend_Frames)
Jun 28 2021, 12:05 PM
  • BF Blender
Jesse Yurkovich (deadpin)
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: rB84da05a8b806
I made the simple cheese by applying boolean modifier then for softness ,i applied subdivision surface ,but its showing not responding
Blend File:
Dinesh Nayak (Blend_Frames) created this task.Jun 28 2021, 12:05 PM
Dinesh Nayak (Blend_Frames) renamed this task from Please Help . In the Latest Stable Version of Blender 2.93.0 LTS Subdivision surface not working and it failed after execution of boolean modifier to Please Help . In the Latest Stable Version of Blender 2.93.0 LTS Subdivision surface not working in sometimes and it failed after execution of boolean modifier .Jun 28 2021, 1:00 PM
Dinesh Nayak (Blend_Frames) renamed this task from Please Help . In the Latest Stable Version of Blender 2.93.0 LTS Subdivision surface not working in sometimes and it failed after execution of boolean modifier to In the Latest Stable Version of Blender 2.93.0 LTS Subdivision surface not working in sometimes and it failed after execution of boolean modifier .Jun 28 2021, 3:09 PM
Jesse Yurkovich (deadpin) added a subscriber: Jesse Yurkovich (deadpin).Jun 28 2021, 9:03 PM
This is most likely a duplicate of T60733
Meshes with n-gons will drastically decrease the performance of the current implementation. The cheese model has many such faces and each such face has too many vertices. The cheese model as-is is not suitable for subdivision (there are no holding edges etc.); even using the simple subdivision scheme most likely won't produce a good result.
