Maniphest T89773
Shortcut F to link nodes in geometry nodes does not work with multi input sockets (Join Geometry node)
Closed, DuplicateBUG
None
Christoph Duyster (LuckyChris)
Jul 10 2021, 11:13 AM
  • BF Blender
  • Nodes & Physics
  • Geometry Nodes
Bruno (brunochartier)
Pratik Borhade (PratikPB2123)
Thibault de Villèle (thibaulltt)
Platform: macOS-11.4-x86_64-i386-64bit
Graphics Card: AMD Radeon Pro 5500M OpenGL Engine
Broken version: 3.0.0 Alpha, branch: master, commit date: 2021-07-07 17:49, hash: rB139c3f791ed4
Short Description of error
The shortcut F to link nodes in geometry nodes does not work with Join geometry node for multi inputs.
Christoph Duyster (LuckyChris) created this task.Jul 10 2021, 11:13 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.EditedJul 10 2021, 2:21 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Can not reproduce on on 3.0.0 (rB62d9dabc7db4). Possibly you made some changes in keymap
Can you please try again with factory settings (File -> Defaults -> Load Factory Settings).
If that does not help then please provide userprefs located in the directory C:\Users\user_name\AppData\Roaming\Blender Foundation\Blender\3.0.0\config\
Pratik Borhade (PratikPB2123) edited projects, added BF Blender; removed Geometry Nodes.Jul 10 2021, 2:22 PM
Christoph Duyster (LuckyChris) added a comment.Jul 10 2021, 2:49 PM
i do not think that this makes sense, because other nodes in gn and shader nodes i can link with "F"...Did you really try to connect to "join geometry node"?
Christoph Duyster (LuckyChris) added a comment.Jul 10 2021, 2:54 PM
maybe it is a mac-only problem :(
Christoph Duyster (LuckyChris) added a comment.Jul 10 2021, 2:55 PM
ok, after testing a bit, there seem only "special cases" where it does not work....
Christoph Duyster (LuckyChris) added a comment.EditedJul 10 2021, 2:57 PM
sorry for my "bad" description. Now i found out. If join geometry node already has a connection like this:
and you want to join another one and select the "join " node and the new one - it won't connect, if you press "F" - of course with mouse it works.
Pratik Borhade (PratikPB2123) added a comment.EditedJul 10 2021, 2:58 PM
I misread "join geometry node" as "geometry nodes" :p (my bad). Think the "F key" fails for multi inputs.
(Will check if this is expected behavior or not)
Christoph Duyster (LuckyChris) added a comment.Jul 10 2021, 2:59 PM
I hope it should be expect behaviour....because "join" node has only one input...so there should be no "problem" at all....hopefully...
Pratik Borhade (PratikPB2123) updated the task description.Jul 10 2021, 3:13 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Jul 12 2021, 7:31 AM
Christoph Duyster (LuckyChris) added a comment.Jul 12 2021, 7:34 AM
what information do you need?
Philipp Oeser (lichtwerk) renamed this task from Shortcut F to link nodes in geometry nodes does not work with Join Geometry node to Shortcut F to link nodes in geometry nodes does not work with multi input sockets (Join Geometry node).Jul 30 2021, 2:41 PM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.
Philipp Oeser (lichtwerk) added projects: Nodes & Physics, Geometry Nodes, Nodes.
Thibault de Villèle (thibaulltt) added a subscriber: Thibault de Villèle (thibaulltt).
Hi, @Christoph Duyster (LuckyChris) I have found a solution to your problem. I have created the diff D12702 and I'm waiting for review and approval but it should fix your issue.
Thibault de Villèle (thibaulltt) claimed this task.Sep 29 2021, 5:38 PM
Hans Goudey (HooglyBoogly) changed the subtype of this task from "Report" to "Bug".Nov 11 2021, 9:20 PM
Hans Goudey (HooglyBoogly) removed Thibault de Villèle (thibaulltt) as the assignee of this task.Feb 1 2022, 11:52 PM
Hans Goudey (HooglyBoogly) removed a project: Nodes.May 16 2022, 11:05 AM
Bruno (brunochartier) added a subscriber: Bruno (brunochartier).Dec 23 2022, 11:14 PM
I think that's a duplicate with T93413?
Pratik Borhade (PratikPB2123) added a comment.Dec 24 2022, 3:50 AM
Looks same indeed. Thanks @Bruno (brunochartier) for finding it :)
Pratik Borhade (PratikPB2123) closed this task as a duplicate of T93413: make links in geometry node editor doesn't work with multi input socket.Dec 24 2022, 3:50 AM
