Maniphest T90007
Affect only Parents and parented objects
Closed, Duplicate
None
Adrian (LalaGhost)
Jul 21 2021, 10:36 AM
  • BF Blender
  • Modeling
  • User Interface
Adrian (LalaGhost)
Philipp Oeser (lichtwerk)
Pratik Borhade (PratikPB2123)
Graphics card: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.89
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: rB84da05a8b806
Moving an object with a child via the Item Panel>Transform while Affect only Parents is enabled does move the child with it.
  1. Create a cylinder and a cube
  2. Parent the cube under the cylinder
  3. Enable Affect only Parents
  4. Go the Item Panel>Transform where you can type the values in and change the location, rotation, scale or dimension.
  5. The parented object moves even though it should not
The function does work when you try to move the object via the viewport but not if you type values in or use the transform values text fields as a slider.
Screenshot of the setup:
Test File:
Adrian (LalaGhost) created this task.Jul 21 2021, 10:36 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Jul 21 2021, 11:57 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.EditedJul 21 2021, 12:10 PM
Pratik Borhade (PratikPB2123) added projects: Modeling, User Interface.
Thanks for the report. Can confirm the issue with 3.0.0 (rBd218ba80095bbf36db458fe2636e06c6dda14465)
Could not find a similar issue reported before (Will check again)
Pratik Borhade (PratikPB2123) updated the task description.Jul 21 2021, 12:12 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jul 21 2021, 2:03 PM
This is the same as T71437: Affect Only: Origin/Parents not working in Transform Panel of the 3D View
So it is an option for the transform system, not for object properties (even though this is not 100% consistent [at least one operator is using that setting as well]).
Not considered a bug atm., will merge these reports
