Maniphest T91170
Rotate with "R" key ONLY from front and back cameras affects axis X and Z rotation with very small values.
Closed, Duplicate
None
Rodrigo Sauré (rodrigosaure)
Sep 3 2021, 5:23 PM
  • BF Blender
  • Modeling
Germano Cavalcante (mano-wii)
Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 2.93.2, branch: master, commit date: 2021-08-03 05:58, hash: rB1eb06de2607a
Rotate with "R" key ONLY from front and back cameras affects axis X and Z rotation with very small values. While rotating with "R" key from FRONT and BACK cameras not only Y axis rotates, it also affects axis X and Z with very small values. This does not happen from others orthographic views. This also happens with any created camera oriented in the exactly front or back view.
  • Launch startup file
  • Press Numpad+1 to view the front side
  • Select default cube
  • Press "R" on the keyboard and rotate the cube
  • Check rotation values on the Object Properties menu
  • For example if you rotate the Y axis to 89.9, X and Z axis rotates -0.00112
Rodrigo Sauré (rodrigosaure) created this task.Sep 3 2021, 5:23 PM
Pratik Borhade (PratikPB2123) updated the task description.Sep 5 2021, 12:34 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Sep 5 2021, 12:36 PM
Pratik Borhade (PratikPB2123) added a project: Modeling.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Sep 8 2021, 5:32 PM
This is a known issue and has been reported in T76629: Grab and Rotate in Front view mini bug.
But it was closed because it "isn't something we will address".
Germano Cavalcante (mano-wii) closed this task as a duplicate of T76629: Grab and Rotate in Front view mini bug.Sep 8 2021, 5:32 PM
