Maniphest T91506
does not process the composer
Closed, Duplicate
None
Alexey (pseudoua)
Sep 18 2021, 9:15 PM
  • BF Blender
  • Compositing
Alexey (pseudoua)
Richard Antalik (ISS)
Operating system: Windows 10 Home 64
Graphics card: 3080ti 12g
Broken:
2.93.4, branch: master, commit date: 2021-08-31 09:23, hash: b7205031cec4, type: release
3.0.0 Alpha, branch: master, commit date: 2021-09-06 16:56, hash: d7d8eb7de468, type: release
F12 - on Open Project - OK
Ctrl-F12 - output files without composer processing
Related Objects
Mentioned Here
rBb7205031cec4: Version bump: 2.93.4-release
Alexey (pseudoua) created this task.Sep 18 2021, 9:15 PM
Alexey (pseudoua) updated the task description.Sep 18 2021, 9:17 PM
Alexey (pseudoua) added projects: Compositing, Render & Cycles.Sep 18 2021, 9:31 PM
Alexey (pseudoua) removed a project: Render & Cycles.Sep 18 2021, 10:20 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).Sep 29 2021, 6:33 PM
There are 2 issues - you are writing output image with node to same location as render, but ths is not causing problems. The problem is caused by glare node with combination of PNG output format. Glare node causes image to have pure emissive colors which are not supported by PNG. You should use format like OpenEXR.
Alternatively you can mask this area and override alpha yourself, or apply greenscreen to convert pure emissive colors to normal transparency.
