Maniphest T91642
Certain video files decoded incorrectly
Closed, Archived
Sebastian Parborg (zeddb)
Sep 23 2021, 2:35 PM
  • BF Blender
  • VFX & Video
Ray Molenkamp (LazyDodo)
Richard Antalik (ISS)
Operating system: Gentoo Linux
Graphics card: AMD Vega 64
Broken: master
When decoding certain video clips, the decoded output is not correct.
  1. Download
  2. Open in Blender master
  3. Notice that the decoded video frame has a section of the side that is not correctly decoded:
Sebastian Parborg (zeddb) changed the task status from Needs Triage to Confirmed.Sep 23 2021, 2:35 PM
Sebastian Parborg (zeddb) claimed this task.
Sebastian Parborg (zeddb) created this task.
Sebastian Parborg (zeddb) added a project: VFX & Video.
Richard Antalik (ISS) added subscribers: Ray Molenkamp (LazyDodo), Richard Antalik (ISS).Sep 23 2021, 5:31 PM
Since @Ray Molenkamp (LazyDodo) suggests, that this is issue with our implementation, I checked with libs from 2.93 and can't reproduce the issue. Can reproduce with stock ffmpeg libs though.
I will recompile ffmpeg, because I deleted libs by accident and check if this could be issue in sws_scale, I think I have changed interpolation in 3.0.
Sebastian Parborg (zeddb) added a comment.Sep 23 2021, 6:04 PM
Yes, I tested this with upstream libs on my linux machine as well. So I think it is on our end too.
Let me know what you find with sws_scale. I will be busy with other tasks for a while now so I can't look into this for a while.
Richard Antalik (ISS) added a comment.Sep 23 2021, 7:34 PM
Just checked, ffmpeg -ss 00:00:05.00 -i a.avi -frames:v 1 a.png does do XXX->RGBA conversion, which seems to be OK. My commit I mentioned was 1f557867916b, but after reverting, issue persists.
I tried converting to some funny pixel formats like AV_PIX_FMT_RGB444LE which is 16bpp, this did resulted obviously in funny image (half size + funny color) but it was only 423px wide instead of 427px, so not quite sure what is going on there...
Also I have noticed, that need_aligned_ffmpeg_buffer(anim) returns true for this file, but this still doesn't quite lead me anywhere.
So I made 3 files:
  • with size so it is memory aligned: ffmpeg -i a.avi -s 864x486 aligned.avi - Does not have this issue
  • with size so it is not memory aligned: ffmpeg -i a.avi -s 865x486 not-aligned.avi - Does have this issue
  • Just recoded, but not memory aligned:fmpeg -i a.avi recoded.avi - Does have this issue
So I think I have found the cause, but I am quite sad I can't reproduce it outside of Blender. I have inspected buffers in anim_movie.c:927-935 and buf_srcis already "incorrect". anim->pFrame buffer looks good to me too, so it must be sws_scale
Richard Antalik (ISS) added a comment.Sep 23 2021, 7:40 PM
Actually I was incorrectly assuming command that should do conversion to RGBA... double checked with how T80912 was debugged...
So ./ffmpeg.exe -ss 00:00:05.00 -i a.avi -vframes 1 -pix_fmt rgba test.png produced following output:
Not quite same as here, but I think good enough to blame ffmpeg
Ray Molenkamp (LazyDodo) added a comment.Sep 23 2021, 7:48 PM
With the above command, I can repro with the the nightly ffmpeg from today, reporting it upstream may be the way to go here, we should probably trim that avi file a little though before we do, 200+ megs seems excessive
Ray Molenkamp (LazyDodo) added a comment.Sep 23 2021, 8:03 PM
I'm way out of my comfort zone here, i haven't got the faintest idea what most of these values mean... but...
i tried some random files i had and they all come out fine and have this output from ffprobe.
Stream #0:0: Video: h264 (High), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
while the a.avi file has:
Stream #0:0: Video: mpeg4 (Simple Profile) (FMP4 / 0x34504D46), yuv420p, 854x480 [SAR 1:1 DAR 427:240], 2500 kb/s, 24 fps, 24 tbr, 24 tbn
get it be the wonky DAR value that is causing the problem?
Richard Antalik (ISS) added a comment.Sep 23 2021, 8:38 PM
Reported here https://trac.ffmpeg.org/ticket/9435.
I can check other formats, but I think this fails if x resolusion is not divisible by 32. As far as sws-scale is concerned in both cases above pixel format conversion is from YUV420P to RGBA.
Richard Antalik (ISS) closed this task as Archived.Nov 15 2022, 10:08 PM
Fixed upstream, closing.
