Graphics card: NVIDIA GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.96
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-11 23:14, hash: rB4b31a21bcd19
Honestly not sure whether this is actually a bug. It renders an image with alpha channel being 0, but still visible. I don't understand what's happening.
Use a Principled BSDF that has the Alpha slider set to 0.5, and use Add Shader to add it with a Transparent BSDF, with Film Transparent on, results in a visible image with strange Alpha channel (almost 0) in the final image:
Note the dim outline of the plane visible in the Alpha channel (In Cycles)
In Eevee's Alpha Blend mode the Alpha of the final image is just darkness without the dim outline.
I mean, how come it's still visible with 0 alpha? Saving EXR works but saving PNG doesn't. I honestly don't know what's happening.
Based on an attached .blend file
- Open the file and hit render
- After rendering finished, go to top right corner of the render window and switch channel to Alpha, see the dark image with dim outline
- Switch to Eevee and hit render, see the alpha of the final image, see how it's completely dark.
- Go to the compositor and do something like this:
This is an image still visible with 0 alpha?!
