Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 2.83, 2.93.2
Worked: version: 2.80
There is an issue with empties "blocking" object outlines. It renders empty in front of outline only, not the actual object.
Also, it only happens when in X-ray mode. When you go to Edit Mode you can see the wireframe properly but when you go to Object Mode you can't see the outline as if the Empty was in front of the selected object.
The Empty object's Viewport property "In Front" is disabled.
See video for better understanding.
- Open new scene.
- Drag & drop an image to the viewport to create an "empty" with the image.
- Create an object (or default cube is fine).
or
- Open attached file
