Maniphest T93077
Can't launch Blender 2.93.5
Closed, Archived
None
Romain Vacher (TheBeatBang)
Nov 14 2021, 9:17 PM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: Windows 10 Professionnel 64bits
Graphics card: Geforce GTX970
Broken: 2.93.5
Worked: 2.81
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FFC88BF432C
Module :
Thread : 000018ec
Switching to fully guarded memory allocator.
Blender 2.93.5
Build: 2021-10-06 06:44:49 Windows release
argv[0] = E:\BLENDER\blender-2.93.5-windows-x64\\blender
argv[1] = --debug
argv[2] = --debug-gpu
argv[3] = --debug-gpu-force-workarounds
argv[4] = --python-expr
argv[5] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\Sarcive\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
read file
Version 293 sub 18 date 2021-04-16 16:00 hash 463b38b0e0b0
Writing: C:\Users\Sarcive\AppData\Local\Temp\blender.crash.txt
Romain Vacher (TheBeatBang) created this task.Nov 14 2021, 9:17 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Nov 15 2021, 7:13 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Hi, thanks for the report. Could you load 2.93.5 from blender_factory_startup.cmd (located in the same directory where blender.exe is?
Please also attach crash logs: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#crash-log
Romain Vacher (TheBeatBang) added a comment.Nov 16 2021, 4:41 AM
Hi Patrick,
Still not launching.
Address : 0x00007FFF6D74432C
Module :
Thread : 00002ed4
Pratik Borhade (PratikPB2123) added a comment.Nov 16 2021, 6:45 AM
Hi, thanks for checking. Could you please add those files?
  • Open blender_debug_log.cmd (located in the same directory where blender.exe is)
  • Reproduce the crash.
  • Windows explorer will open with two files (add those files here)
  • Open blender_debug_output.txt
  • At the very bottom you will find the path for blender.crash.txt
  • Then also the file blender.crash.txt
Romain Vacher (TheBeatBang) added a comment.Nov 16 2021, 6:19 PM
Much thanks for your help Patrick. Here the files.
Romain Vacher (TheBeatBang) added a comment.Nov 18 2021, 5:28 AM
Hi Patrick I still Can't open Blender, Have you managed to take a look at the crash log ?
Thanks.
Pratik Borhade (PratikPB2123) added a comment.Nov 18 2021, 6:45 PM
Hi, please also attach System Info file generated after the crash.
No call stack generated after the shut down so I am not sure about the reason for crash :/
Could you please try again after updating the driver?: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/windows/nvidia.html
Romain Vacher (TheBeatBang) added a comment.Nov 19 2021, 5:09 AM
Hi Patrick,
My driver has been updated, blender but still crashing at launch.
Where do I finf the System info file ? Nothing appears in Temp dir.
Last thing I've done before crashing was to install addons on blender 2.92 Hardops23_1 ; Boxcutter719_4 ; cablerator1.3.0
Thanks
Romain Vacher (TheBeatBang) added a comment.Nov 19 2021, 5:11 AM
Hi Patrick,
Find attached My config.
Thanks{F11827399}
Romain Vacher (TheBeatBang) added a comment.Nov 20 2021, 2:00 AM
Hi patrick,
Here is the system info from the 2.81 running version
Also Let me mention version 2.81 is running but displaying strange artefacts, plese see Gif attached.
Pratik Borhade (PratikPB2123) added a comment.Nov 20 2021, 11:18 AM
Where do I find the System info file ? Nothing appears in Temp dir.
Hi, file will generate after the crash along with blender_debug_output.txt as said in T93077#1254224
Not sure then. Your driver is also updated. Does this glitches happen for specific file?
Can you reproduce this on recent 2.93LTS?: https://www.blender.org/download/
Romain Vacher (TheBeatBang) added a comment.Nov 20 2021, 4:53 PM
Hi Patrick,
No systeminfo.text is generated. Please see
I tried launching 2.93.6 2.93.5 2.93.0 None of them are launching.
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Nov 28 2021, 1:16 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Feb 4 2022, 7:50 AM
@Romain Vacher (TheBeatBang) , does this issue still exists?
Does this happen on 3.0.0 or daily builds?
Factory startup should have worked for you if add-on causing the issue.
Have you tried running blender_debug_gpu_glitchworkaround.cmd? That will enable all available workarounds for driver issues.
Pratik Borhade (PratikPB2123) closed this task as Archived.Feb 16 2022, 6:15 AM
Romain Vacher (TheBeatBang) added a comment.Feb 16 2022, 8:38 AM
Hi Patrik,
Thanks for coming back to me.
The source of the problem was coming from an old wacom intuos driver. Desinstalling it solved the problem.
Thanks
