Maniphest T93147
Improved way to display weight painting colors
Needs Information from Developers, NormalTO DO
None
Daniel Salazar (zanqdo)
Nov 17 2021, 2:34 AM
  • Animation & Rigging
  • BF Blender
Andy Cuccaro (AndyCuccaro)
Colin Basnett (cmbasnett)
Kevin C. Burke (blastframe)
Philipp Oeser (lichtwerk)
Sybren A. Stüvel (sybren)
Tokens
"Like" token, awarded by blastframe.
Weight group colors in vertices blend between their neighbors by going through the entire range of values between the 2 points
For example if a vertex has a 1.0 (red) value and one of it's neighbors has a 0.0 (blue) value, the face will show a rainbow interpolation going trough orange, yellow, green, cyan and finally blue
In certain situations where each of the vertices of a face have different values (like 1.0, 0.5, 0.75, 0.0) it will create weird intersections in the middle that look like there is a vertex there that doesn't exist
The problem is even worst when the wireframe is not displayed and we only see gradients of colors indicating vertex values that do not exist
The solution is to fix the color blending mode to simply mix between the 2 neighboring colors. This way it is very clear that vertices have values of 1.0, 0.75 and 0.5 and nothing in between.
Daniel Salazar (zanqdo) created this task.Nov 17 2021, 2:34 AM
Daniel Salazar (zanqdo) updated the task description.Nov 17 2021, 2:59 AM
Kevin C. Burke (blastframe) awarded a token.Nov 17 2021, 6:39 AM
Kevin C. Burke (blastframe) added a subscriber: Kevin C. Burke (blastframe).
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Mar 10 2022, 12:46 PM
Philipp Oeser (lichtwerk) added a project: BF Blender.
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "To Do".
Philipp Oeser (lichtwerk) added subscribers: Sybren A. Stüvel (sybren), Philipp Oeser (lichtwerk).
@Sybren A. Stüvel (sybren) : is this something you want to keep as a reference?
Daniel Salazar (zanqdo) added a comment.Mar 11 2022, 8:01 PM
Hi, this is something we discussed in an animation module meeting hence the addition to the module board
Andy Cuccaro (AndyCuccaro) added a subscriber: Andy Cuccaro (AndyCuccaro).May 13 2022, 12:08 AM
Colin Basnett (cmbasnett) added a subscriber: Colin Basnett (cmbasnett).May 13 2022, 12:20 AM
