Maniphest T93156
Cycles X crashing when using HIP in 3.0 Beta
Closed, Archived
None
dec (dec35)
Nov 17 2021, 1:47 PM
  • Render & Cycles
  • BF Blender (3.0)
Brecht Van Lommel (brecht)
dec (dec35)
Thomas Dinges (dingto)
Operating system: Windows-10-10.0.22000-SP0 64 Bits This is what Blender says even though I'm running Windows 11 21H2
Graphics card: AMD Radeon RX 5600M ATI Technologies Inc. 4.5.14761 Core Profile Context 21.11.2 30.0.13033.5003
Broken: version: 3.0.0 Beta, branch: master, commit date: 2021-11-15 19:28, hash: rBa040d2a93a7d
Worked: 2.93.0 I haven't tried any newer version since 2.93.0 came out except 3.0
Every time I start the render using Cycles and HIP as a renderer, blender crashes. The viewport display is totally inaccurate, showing black and white shapes instead of the project. That does not happen when using Evee.
Create a new project, go into settings, select HIP and my graphics card, go into the project (default cube with metal texture on it with a sun, a simple textured plane and a camera, no HDRI), select Cycles and GPU compute, press F12 and then blender crashes.
dec (dec35) created this task.Nov 17 2021, 1:47 PM
dec (dec35) edited projects, added Render & Cycles, BF Blender (3.0); removed BF Blender.
dec (dec35) updated the task description.Nov 17 2021, 1:49 PM
Thomas Dinges (dingto) changed the task status from Needs Triage to Needs Information from User.Nov 17 2021, 1:50 PM
Thomas Dinges (dingto) added a subscriber: Thomas Dinges (dingto).
dec (dec35) added a comment.Nov 17 2021, 2:06 PM
Are you telling me only 6000 gen amd cards can run cycles X ? Thats very disapointing...
dec (dec35) changed the task status from Needs Information from User to Needs Information from Developers.Nov 17 2021, 3:13 PM
Thomas Dinges (dingto) changed the task status from Needs Information from Developers to Needs Information from User.Nov 17 2021, 3:53 PM
Have you installed the driver, I linked you to?
It works on RNDA and RDNA2 cards. https://code.blender.org/2021/11/next-level-support-for-amd-gpus/
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).Nov 17 2021, 4:48 PM
If it works after installing that driver, this can be considered a duplicate of T93109: Cycles HIP device missing driver version check.
dec (dec35) added a comment.Nov 17 2021, 4:53 PM
Compatibility: Cycles X in Blender 3.0 is enabled on AMD RDNA™ architecture graphics cards and up, and support has been validated by AMD on the following desktop graphics cards:
AMD Radeon™ PRO W6800
AMD Radeon™ 6900 XT
AMD Radeon™ 6800 XT
AMD Radeon™ 6800
AMD Radeon™ 6700 XT
AMD Radeon™ 6600 XT
AMD Radeon™ 6600
Mine is a laptop GPU and it is not listed. I can't even install the drivers : When launching the exe download, I get this message : This app can't run on your PC. To find a compatible version, please contact the developers.
Thomas Dinges (dingto) closed this task as Archived.Nov 17 2021, 4:54 PM
In that case this is a driver limitation and unfortunately nothing we can fix. It works on desktop RDNA cards though (I run a 5500 XT myself), so your card might be added in the future.
