Maniphest T93171
material index isn't re-captured after realize instances node (unlike other attributes (uv_map)
Closed, Archived
None
michael campbell (3di)
Nov 18 2021, 12:54 AM
  • BF Blender
  • Geometry Nodes
Jacques Lucke (JacquesLucke)
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-11-11 18:53, hash: rB0533f2851e7e
open below file and change the material index on the set material index node. After the realize instances node the value is not retrieved (unlike the uv_map attribute).
michael campbell (3di) created this task.Nov 18 2021, 12:54 AM
michael campbell (3di) added a project: Geometry Nodes.Nov 18 2021, 1:00 AM
Jacques Lucke (JacquesLucke) closed this task as Archived.Nov 19 2021, 9:40 AM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
The Realize Instances node (just like the Join Geometry) node is allowed to change material indices. This is required for correct behavior when merging multiple geometries with different materials. You can't rely on the material index remaining stable here. Just use the Set Material node instead of dealing with material indices manually. I'm starting to think it was a mistake to add the Set Material Index node.
Ref T93177.
