Maniphest T93176
Exported GLB file has incorrect albedo colors (linear/gamma issue)
Closed, Archived
None
Felix Herbst (herbst)
Nov 18 2021, 1:28 AM
  • BF Blender
Julien DUROURE (julien)
Scurest (scurest)
Graphics card: NVIDIA GeForce RTX 2070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 2.93.6, branch: master, commit date: 2021-11-16 14:54, hash: rBc842a90e2fa1
Exporting the attached blend file to GLB results in an incorrect albedo color (too dark) in the resulting file.
The result file can be viewed in e.g. Unity, Windows 3D VIewer, Babylon etc.
Download
Note light green color
Export to GLB
View the GLB file
Note color is too dark
Create a new scene in blender
Import the file
Note color is too bright
Original File
Re-Imported after GLB Export
GLB Export viewed in Windows 3D Viewer
See also https://developer.blender.org/T93174, same issue with FBX, Blender issue instead of export plugin issue?
Felix Herbst (herbst) created this task.Nov 18 2021, 1:28 AM
Felix Herbst (herbst) updated the task description.
Scurest (scurest) added a subscriber: Scurest (scurest).Nov 18 2021, 2:04 AM
This actually isn't a linear/gamma issue. All colors in glTF are stored in linear space and the glTF addon (hopefully) handles that.
The reason is the vertex colors. In glTF, the first vertex color layer is always multiplied into the base color. There is no way to inhibit this at the material level, the only way the exporter could stop it is by not exporting the vertex colors at all.
So after exporting to glTF, the glTF material is going to be affected by the vertex colors.
If you export with the Geometry > Vertex Colors option off, the exported .glb will match the original model.
Julien DUROURE (julien) added a subscriber: Julien DUROURE (julien).Dec 12 2021, 8:45 AM
Julien DUROURE (julien) closed this task as Archived.Dec 12 2021, 8:50 AM
Seems there is no issue, closing.
Don't hesitate to answer if needed
