Maniphest T93182
SOMETIMES MY IMAGE IS NOT VISIBLE ONLY BORDER IS VISIBLE
Closed, Archived
None
ANAS KHAN (ANASKHAN1989)
Nov 18 2021, 12:53 PM
  • BF Blender
Demeter Dzadik (Mets)
CORE 13
WINDOW 10:
RADEON 2 GB:
2.93.4
WHEN I TRY TO INSERT AN IMAGE MAXIMUM TIMES IT'S ONLY BORDER IS VISIBLE, AND I CAN'T SEE THE IMAGE
ANAS KHAN (ANASKHAN1989) created this task.Nov 18 2021, 12:53 PM
Demeter Dzadik (Mets) closed this task as Archived.EditedNov 18 2021, 12:58 PM
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).
First of all, please try turning off your caps lock key:
https://www.wikihow.com/Turn-Off-Caps-Lock
If that doesn't fix the issue, you should submit a new report with all the necessary information filled out so that somebody can actually help you.
