Maniphest T93212
[Chore] Migrate to PostgreSQL
Closed, ResolvedTO DO
Anna Sirota (railla)
Nov 19 2021, 3:50 PM
  • Blender ID
Goal
The goal of this migration is to have a more unified (in terms of number of technologies used) web infrastructure, starting with at least having all Django projects use the same RDBMS. This makes running local development setups and having exactly the same up-to-date dependencies everywhere easier.
One downside to this is the way PostgreSQL major version upgrades have to be done, but this would produce an issue once every several years, while upgrades of Django and surrounding boilerplate of DB client libs and other deps have to happen much more often.
The machine, which runs production Blender ID, already has a PostgreSQL container, so, if production data is moved successfully, doing the swithcover should be easy.
The main problem is copying the data with minimal disruptions.
How production data is copied
./manage.py dumpdata|loaddata were considered, but without extra hacks, such as migrating first, then truncating all the tables, loaddata won't actually be able to load all the data. Not only that, but it's also problematic because loaddata will trigger all signals, which we don not want to do for all the production data.
Luckily for us, latest https://pgloader.io/ (version 3.6.2 at the moment of writing) does a good job of copying data directly from a running MySQL to a running PostgreSQL.
It has to be built from sources because Debian/Ubuntu are much behind the currently stable working version, as usual. Let's assume we've done that and pgloader binary is now located at /opt/pgloader/pgloader-bundle-3.6.2.
In order to be able to copy from MySQL instance to PostgreSQL one, pgloader must have access to both, so new user, database and schema must be created in PostgreSQL instance (these can be the same ones Blender ID will later use). Something along these lines executed in psql should do the trick:
postgres=# CREATE USER blender_id CREATEDB PASSWORD ??????;
postgres=# CREATE DATABASE blender_id OWNER blender_id;
postgres=# \c blender_id;
You are now connected to database "blender_id" as user "postgres".
blender_id=# CREATE SCHEMA blender_id;
blender_id=# GRANT CONNECT ON DATABASE blender_id TO blender_id;
GRANT
blender_id=# GRANT USAGE ON schema blender_id TO blender_id;
GRANT
blender_id=# GRANT ALL ON schema blender_id TO blender_id;
GRANT
pgloader also needs to be able to connect to both instances, so we need to find IPs of their containers:
for n in `docker network ls  | awk '{print $1}'`; do docker network inspect $n | grep -E 'postgr|mysql' -A 3 | grep -iE 'name|ip.*address' ; done
This outputs something along the lines of
"Name": "postgres",
"IPv4Address": "172.22.0.4/16",
"Name": "mysql",
"IPv4Address": "172.22.0.8/16",
A script for copying the data can look as follows:
#!/bin/bash
PGLOADER=/opt/pgloader/pgloader-bundle-3.6.2/bin/pgloader
MYSQL_IP=172.22.0.8
PSQL_IP=172.22.0.4
MYSQL_IP="${MYSQL_IP}" PSQL_IP="${PSQL_IP}" \
        PGPASSWORD=?????? \
        MYSQL_PWD=?????? \
	$PGLOADER --verbose mysql_to_psql.load
where contents of mysql_to_psql.load looks like this:
LOAD DATABASE
    FROM mysql://blender_id@{{MYSQL_IP}}:3306/blender_id
    INTO postgresql://blender_id@{{PSQL_IP}}:5432/blender_id
CAST
    column bid_main_user.last_login_ip to inet drop typemod,
    column bid_main_user.current_login_ip to inet drop typemod
Issues encountered
Invalid datetime values
The first attempt produced some errors due to invalid datetime values:
ERROR Database error 23502: null value in column "date_joined" violates not-null constraint
This is because MySQL has a bug that allows inserting invalid 0000-00-00 00:00:00 DATETIME values, which are later treated as NULLs, which in turn breaks the NON NULL constraint for these values.
Invalid inet values
PostgreSQL has a data types for IP addresses and these used by Django's GenericIPAddressField, which means that all values contained by last_login_ip and current_login_ip must be castable to inet, otherwise row will fail to be copied with the following error:
2021-11-19T16:28:54.816000Z ERROR Database error 22P02: invalid input syntax for type inet: "192.168.168.116, 127.0.0.1"
CONTEXT: COPY bid_main_user, line 14055, column current_login_ip: "192.168.168.116, 127.0.0.1"
To find all offending records we can use:
SELCT id, last_login, email, current_login_ip, last_login_ip FROM bid_main_user WHERE current_login_ip NOT REGEXP '^[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}$' OR last_login_ip NOT REGEXP '^[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}$';
These also have to be fixed manually before data can be copied fully.
Constraint names are truncated
Updating the rows with invalid values and running pgloader again produces no errors, but still produces a lot of warnings about some obnoxiously long index/constraint names being truncated. E.g.:
2021-11-19T10:51:04.069000Z WARNING PostgreSQL warning: identifier "idx_233110_oauth2_provider_gran_application_id_81923564_fk_bid_main_" will be truncated to "idx_233110_oauth2_provider_gran_application_id_81923564_fk_bid_"
As far as I can tell, this doesn't break anything because the truncated names were still unique and constraints and indices were still created, so for now we assume this is a non-issue.
At this point we have a full copy of Blender ID's production data in our PostgreSQL instance 🎉
To be continued:
  • deploying missing PostgreSQL deps to production (see linked commits);
  • switching Django's database configuration;
Recap of the migration
switch to maintenance
# show a maintenance page
docker exec -it blender-id sh
uwsgi --stop /var/run/uwsgi/blender-id.pid  # did not work, see plan B below
# plan B: add maintenance mode to nginx config
nginx -t
pkill -HUP nginx
touch /var/www/maintenance_on
# stop cron
sudo systemctl stop cron
backup everything
sudo /bin/bash /var/www/blender-id/backup.sh
sudo -Hu dbbackup /var/www/sintel-blender-org-management/postgresql_backup.sh
copy and switch
# copy the data
cd /opt/pgloader/
bash copy_mysql_to_psql.sh 2>&1 | tee pgloader101.log
# check pgloader101.log: should have 0 errors
# change default database
vim /var/www/blender-id/settings/blender_id_settings.py
bring everything back
# restart UWSGI
uwsgi --reload /var/run/uwsgi/blender-id.pid
# hide a maintenance page
# uwsgi /etc/uwsgi/uwsgi.ini
rm /var/www/maintenance_on
# start cron
sudo systemctl start cron
Revisions and Commits
rBID Blender ID
Related Objects
Mentioned In
T93515: Migrate to PostgreSQL
rBIDeea3aaf3572c: [T93212] Update docs and remove MySQL dependencies
rBID5b9d389a0640: [T93212] Update README about database setup: now for PostgreSQL
Anna Sirota (railla) created this task.Nov 19 2021, 3:50 PM
Anna Sirota (railla) moved this task from Backlog to In progress on the Blender ID board.
Anna Sirota (railla) updated the task description.
Anna Sirota (railla) added commits: rBID5ddeaf8047a6: Add suport for PostgreSQL without removing support for MySQL, rBID27c592e06541: Add missing psql libs, rBID7a13e8c0a0b8: Add psycopg2, rBID4ff88bee7b39: Validate the given email in check user API endpoint.
Anna Sirota (railla) updated the task description.Nov 19 2021, 5:33 PM
Anna Sirota (railla) updated the task description.Nov 22 2021, 9:46 AM
Anna Sirota (railla) updated the task description.Nov 22 2021, 11:00 AM
Anna Sirota (railla) updated the task description.Nov 22 2021, 11:08 AM
Anna Sirota (railla) updated the task description.Nov 26 2021, 2:03 PM
Anna Sirota (railla) updated the task description.Nov 30 2021, 12:24 PM
Anna Sirota (railla) changed the subtype of this task from "Report" to "To Do".
Anna Sirota (railla) moved this task from In progress to Commited/In Review on the Blender ID board.
Anna Sirota (railla) added a commit: rBID02cbd583917f: Configure a maintenance flag for a quick way to enable maintenance mode in nginx.Nov 30 2021, 12:35 PM
Anna Sirota (railla) mentioned this in rBID5b9d389a0640: [T93212] Update README about database setup: now for PostgreSQL.Nov 30 2021, 2:39 PM
Anna Sirota (railla) mentioned this in rBIDeea3aaf3572c: [T93212] Update docs and remove MySQL dependencies.Nov 30 2021, 3:13 PM
Anna Sirota (railla) mentioned this in T93515: Migrate to PostgreSQL.Nov 30 2021, 3:34 PM
Anna Sirota (railla) updated the task description.Dec 1 2021, 11:02 AM
Anna Sirota (railla) changed the task status from Needs Triage to Confirmed.Dec 1 2021, 11:19 AM
Anna Sirota (railla) closed this task as Resolved.Dec 7 2021, 11:35 AM
