Maniphest T93222
Im having a problem conform a object
Closed, Archived
None
Marcus Edwards (marcus87lee)
Nov 19 2021, 6:48 PM
  • BF Blender
Alaska (Alaska)
Pratik Borhade (PratikPB2123)
{F11829230 Attached is a video of how i couldnt download the conformity add on . please help I emailed you three times .System Information
Graphics card: GeForce MX250/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.93.6, branch: master, commit date: 2021-11-16 14:54, hash: rBc842a90e2fa1
Related Objects
Marcus Edwards (marcus87lee) created this task.Nov 19 2021, 6:48 PM
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Nov 19 2021, 10:13 PM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
By the "conformity add-on" do you mean this one? https://blendermarket.com/products/conform-object
If so, then what you need to do is buy it, download it, then select from the top of Blender Edit -> Preferences and go to the Add-on tab and select Install and select the file you downloaded for the add-on then enable it if it hasn't been enabled already.
If this is not the add-on you're talking about, then please provide the proper name of the add-on and a proper description of how it's not working.
Looking at the video you provided you enabled the F2 add-on which doesn't have any Conform like functions in it.
Pratik Borhade (PratikPB2123) merged a task: T93299: Im having a problem conform a object.Nov 22 2021, 5:17 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Pratik Borhade (PratikPB2123) closed this task as Archived.Dec 1 2021, 10:24 AM
Hi, the add-on you are using is not maintained by Blender developers. Please report issue to add-on developer.
Also, No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed.
