Maniphest T93238
Some camera markers on timeline become greyed out and no longer function as expected
Closed, Archived
None
Rowan Ibbeken (Rowquino)
Nov 20 2021, 9:20 AM
  • BF Blender
Richard Antalik (ISS)
Operating system: Windows 10 64-bit
Graphics card: Nvidia RTX 3090
Broken: All versions tested (2.93, 3.0)
Worked: None
A number of camera markers used to switch between active cameras became 'greyed out' at random one day, so that only the ungreyed out markers still function, Blender ignores the rest of the markers and does not switch to their associated cameras at their points on the timeline. Even when the marker is highlighted the text remains greyed out.
  • Open .blend file
  • Click green camera icon beside 'Bedroom Camera 1' to make it active (as it should be at frame 1 since it's the first camera marker on the timeline).
  • Jump to first endpoint on the timeline and the camera will automatically switch to 'Living Room Camera 1', even though its marker only starts at Frame 200 (however, it is the first ungreyed out marker so I suspect this is causing Blender to jump to it).
  • Play the timeline and you will see that the camera does not switch as expected (if at all).
Rowan Ibbeken (Rowquino) created this task.Nov 20 2021, 9:20 AM
Rowan Ibbeken (Rowquino) renamed this task from Camera markers become greyed out at random and no longer function as expected to Some camera markers on timeline become greyed out and no longer function as expected.Nov 20 2021, 11:20 AM
Rowan Ibbeken (Rowquino) added a comment.Nov 22 2021, 9:11 AM
You can see in the picture here how the greyed out markers look compared to the others.
Rowan Ibbeken (Rowquino) added a comment.Nov 24 2021, 10:36 PM
This issue remains unsolved.
Richard Antalik (ISS) closed this task as Archived.Nov 25 2021, 5:10 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
This is because cameras are disabled for render, these cameras don't switch even in viewport. This may be counter intuitive, but it works as designed, so I will close this report. This tracker is only for bugs.
For help using Blender, I would recommend one of the community websites: https://www.blender.org/community/
Rowan Ibbeken (Rowquino) added a comment.Nov 25 2021, 8:32 AM
Thank you!
