This bug is observed only in 3.0 and 3.1
Short Description
When Transform tool's Drag is set to "active tool", Drag action is not saved. It gets swithed to "move" every time I switch object interaction mode to "edit mode" or anything else.
Steps to Reproduce
- Open default blend file
- Select Transform from toolbar
- Drag → Active Tool
- Change Drag Action to any (eg. rotate)
- Toggle edit mode then back to object mode
(Drag Action switched back to Move)
