Maniphest T93434
Sculpt mode remesh broke shading
Closed, Archived
None
Donovane (Stimes)
Nov 27 2021, 6:17 PM
  • BF Blender
  • Sculpt, Paint & Texture
Donovane (Stimes)
Julien Kaspar (JulienKaspar)
Pratik Borhade (PratikPB2123)
Tokens
"Like" token, awarded by PratikPB2123."Love" token, awarded by Stimes.
Operating system: WIN 11 X64
Graphics card: RTX 260 6GB
Broken: 2.93.6
Artifacts appears in Sculpting workspace if plane is remeshed
But when you use the layout Tab is fully work in object mode and edit mode or scultp mode :
edit mode on layout tab : Works (shading no broken)
sculpt mode on layout tab : Works (shading no broken)
but still broken on sculpt mode tab (same in edit mode in tab sculpting)
Steps to Reproduce
  • Open default scene
  • Delete cube and add Plane
  • Switch active workspace from layout to Sculpting
  • Remesh
Blend file :
Related Objects
Mentioned Here
rB63aa10802b32: Fix T93007: Cycles not updating for animated Object properties like color
Donovane (Stimes) created this task.Nov 27 2021, 6:17 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Nov 27 2021, 6:35 PM
Donovane (Stimes) updated the task description.Nov 27 2021, 6:38 PM
Pratik Borhade (PratikPB2123) added a comment.Nov 27 2021, 6:45 PM
Hi, thanks for the report. Can not reproduce on 2.93.7 (4ec6cc412d7f)
Not sure but I suspect this driver issue. Could you please try again with recent driver version: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/windows/nvidia.html
Also, please add system info generated from the Help menu: HelpSave System Info
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Nov 27 2021, 6:45 PM
Donovane (Stimes) added a comment.EditedNov 27 2021, 9:43 PM
My drivers is the latest version i have no update i'm use the studio driver also i have tried with game ready driver i have the same result shading broken.
Studio driver: 427.47 NVIDIA
Config file save :
Also i have tried with 2.93.7 candidate (studio driver and game ready driver both are same problem, the shading was broken only in sculpt mode tab) : November 27, 02:23:18 - 63aa10802b32 - zip - 211.90MB
And is exactly the same result in 2.93.7
The problem come when your put the value 0.01 or any other value in remesh voxel size
Donovane (Stimes) added a comment.EditedNov 27 2021, 9:56 PM
I just want to say the shading was broken only on the sculpt mode tab ! Not on the Layout tab ! Remind you this !
but the bug come when your use a plane always and sometimes on other all meshs
Donovane (Stimes) added a comment.Nov 27 2021, 10:17 PM
This comment was removed by Donovane (Stimes).
Donovane (Stimes) added a comment.Nov 27 2021, 10:21 PM
Video report is most simply for understand, but the bug come when your use a plane first :
Donovane (Stimes) awarded a token.Nov 27 2021, 10:30 PM
Donovane (Stimes) added a subscriber: pratik cirkleinc (pratik).Nov 29 2021, 10:10 PM
Donovane (Stimes) added a comment.Nov 29 2021, 10:11 PM
@Pratik Borhade (PratikPB2123)
ANy update ?
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Confirmed.Nov 30 2021, 8:10 PM
Pratik Borhade (PratikPB2123) added a project: Sculpt, Paint & Texture.
Hi @Donovane (Stimes) , I can reproduce now. Thanks for clarifying.
I think I have seen similar report before but couldn't find at the moment. Confirming.
Donovane (Stimes) added a comment.Nov 30 2021, 8:11 PM
No problem happy for help the the Blender dev :) if i found anything don't worry i report it :)
Pratik Borhade (PratikPB2123) awarded a token.Nov 30 2021, 8:12 PM
Pratik Borhade (PratikPB2123) removed a subscriber: pratik cirkleinc (pratik).
Pratik Borhade (PratikPB2123) updated the task description.Nov 30 2021, 8:25 PM
Julien Kaspar (JulienKaspar) closed this task as Archived.May 10 2022, 10:20 AM
Julien Kaspar (JulienKaspar) added a subscriber: Julien Kaspar (JulienKaspar).
I don't think this is a bug. This is just z-fighting that is only visible in the sculpting workspace because that workspace is using matcap shading. The other workspaces are using studio shading which doesn't highlight the inverted normals that badly. So the same effect is there, just not as visible.
The voxel remesher is also not made for meshes that are thinner than the voxel size or open geometry. It needs to be a closed mesh with a big enough volume.
