Maniphest T93449
blender-3.0. beta can't setting Cycles Render devices
Closed, Resolved
Thomas Luo (thlo7777)
Nov 28 2021, 2:37 PM
  • BF Blender
  • Render & Cycles
Jesse Yurkovich (deadpin)
Thomas Dinges (dingto)
Operating system:
Windows10
Graphics card:
RTX2060
blender-3.0.0-candidate+v30.d2e608733507
Click Edit-> prefrences and select System -> Cycles render devices. There is nothing.
I have a 2.93.6 also, it works very well with Cycles render.
Related Objects
Mentioned Here
rBd2e608733507: Fix build error with TBB 2021 and booleans
Thomas Luo (thlo7777) created this task.Nov 28 2021, 2:37 PM
Thomas Dinges (dingto) added a project: Render & Cycles.Nov 28 2021, 4:55 PM
Thomas Dinges (dingto) added a subscriber: Thomas Dinges (dingto).Nov 28 2021, 8:54 PM
Do you have any errors in your console? Run blender_debug_log.cmd (next to your blender.exe), go to the User Preferences again to Cycles render devices, close Blender and attach the output files here.
Jesse Yurkovich (deadpin) changed the task status from Needs Triage to Needs Information from User.Nov 28 2021, 9:36 PM
Jesse Yurkovich (deadpin) added a subscriber: Jesse Yurkovich (deadpin).
This will typically happen if the "Render: Cycles Render Engine" addon is disabled in user-preferences or some of the files from the download haven't been extracted properly.
Please double-check that the addon is enabled and that you have extracted all the files properly. If that still doesn't address the issue, follow Thomas's suggestion above.
Thomas Luo (thlo7777) closed this task as Resolved.Nov 29 2021, 2:26 AM
Thomas Luo (thlo7777) claimed this task.
Yes, it works when I select addon for Cycles Render engine. Thank you for comments @Jesse Yurkovich (deadpin) and @Thomas Dinges (dingto)
