Maniphest T93478
Impossible to run Modal operator with simultaneously open props dialog (Blender crashes)
Confirmed, NormalBUG
None
Andrei Tihonovschi (atgote)
Nov 29 2021, 3:44 PM
  • BF Blender
  • Python API
Germano Cavalcante (mano-wii)
Operating system: Linux-5.15.4-x86_64-AMD_Ryzen_3_PRO_4350G_with_Radeon_Graphics-with-glibc2.33 64 Bits
Graphics card: AMD RENOIR (DRM 3.42.0, 5.15.4, LLVM 13.0.0) AMD 4.6 (Core Profile) Mesa 21.2.6
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: rB84da05a8b806
2.93.6, 2.93.7, 3.0.0 and 3.1.0 all are broken.
Worked: (don't know)
Blender crashes while trying to display operator properties dialog (invoke_props_dialog) and add
the same operator as the modal handler (modal_handler_add(self))
I think it's the same problem as in the (closed) task T48196
Try to invoke corresponding operator and then to return {'FINISHED'} or {'CANCELLED'} from the modal() handler.
Then blender crashes after pressing ESC or closing dialog.
Sample code:
import bpy
class TEST(bpy.types.Operator):
    bl_idname = "test.modal"
    bl_label = "test invoke props + modal"
    test: bpy.props.StringProperty(
        name="test",
        description="test",
        default=''
    def draw(self, context):
        col = self.layout.column(align=True)
        col.prop(self, "test")
    def invoke(self, context, event):
        context.window_manager.invoke_props_dialog(self)
        context.window_manager.modal_handler_add(self)
        return {'RUNNING_MODAL'}
    def execute(self, context):
        return {'FINISHED'}
    def modal(self, context, event):
        if event.type in {'ESC'}:
            return {'CANCELLED'}
        return {'PASS_THROUGH'}
def register():
    bpy.utils.register_class(TEST)
def unregister():
    bpy.utils.unregister_class(TEST)
if __name__ == "__main__":
    register()
I think that impossibility of creating modal operators which can simultaneously have open properties
dialog for on-the-fly corrections lead to endless tries to create custom bgl-rendered UIs which is just
an unneeded overhead.
Please, review the mentioned bug, AFAIK it was already fixed but somehow reappeared upstream...
Andrei Tihonovschi (atgote) created this task.Nov 29 2021, 3:44 PM
Sybren A. Stüvel (sybren) updated the task description.Nov 29 2021, 4:02 PM
Andrei Tihonovschi (atgote) updated the task description.Nov 30 2021, 10:56 AM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Dec 1 2021, 4:21 PM
Germano Cavalcante (mano-wii) added a project: Python API.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
Thanks for the report, I can confirm the crash with the example operator.
But it doesn't seem to be conventional to use invoke_props_dialog and modal_handler_add in the same operator.
The two modal operations are performed at the same time and both can free the operator, causing the one trying to use the operator later to crash.
I don't know what is the point of running an operator along with a popup, maybe it's better to separate the two things (Menu and operator).
Andrei Tihonovschi (atgote) added a comment.EditedDec 1 2021, 4:41 PM
Just as an example - choose a "modifier" from Enum field which influences the operator action - and user can check the result before finalizing the operator execution (somewhat like with Undo/Redo dialog)
But the idea behind my search was to use modal handler to improve UX when using the props dialog. That is to have dialog responding to keypresses like add or remove (filter) / UI elements (props).
Something alike searching for an operator with operator search dialog (F3) but a little bit more powerful, allowing not only list-search, but UI-elements 'filter' - different operator/presets buttons for example.
That is - user may enter some keystrokes to filter available actions and then press the operator button or may just find the button in the list and press it without using filtering at all.
