Maniphest T93557
[Blender 3.0] Line art is Flickering
Closed, Resolved
YimingWu (NicksBest)
joo (joo)
Dec 2 2021, 1:15 AM
  • BF Blender
  • Line Art
joo (joo)
Poyo (poyoiamayoyo)
Operating system: windows 10
Graphics card: NVIDIA RTX 2070 super
MEMORY : 32GB RAM
Broken: 3.0, f829b86039cb ~ 3788003cdaeb
Worked: a040d2a93a7d
The line art of Blender 3.0 is Flickering and some of it is invisible. Also, performance degrades in busy scenes.
Related Objects
Mentioned In
T93454: blender 3.0 Line art rendering is very slow.
Mentioned Here
rB24b84e468805: LineArt: Use consitent view vector direction.
rBa040d2a93a7d: Fix T90592: Incorrect scrollbar range with backdrop
rBf829b86039cb: Cleanup: Correct copy paste error in comment
rB3788003cdaeb: Fix T93368: Dragging Blends Without Previews
joo (joo) created this task.Dec 2 2021, 1:15 AM
joo (joo) added a project: Line Art.Dec 2 2021, 1:18 AM
joo (joo) updated the task description.
joo (joo) renamed this task from [Blender 3.0] Line art is blinking to [Blender 3.0] Line art is Flickering.Dec 2 2021, 1:55 AM
YimingWu (NicksBest) claimed this task.Dec 2 2021, 6:05 AM
YimingWu (NicksBest) added a subscriber: YimingWu (NicksBest).
Let me investigate.
YimingWu (NicksBest) added a comment.Dec 2 2021, 6:07 AM
In line art branch the file works fine. I'm not sure what change caused the issue, this should be fixed.
joo (joo) added a comment.Dec 2 2021, 6:23 AM
Maybe it causes problems in the indoor scene. Also, there seems to be a memory leak problem. https://developer.blender.org/T93454
YimingWu (NicksBest) closed this task as Resolved.Dec 2 2021, 6:42 AM
Hi there, I compiled the 3.0 release branch just now, it works fine now. I think It's the emergency fix 24b84e46 I pushed yesterday that did the trick.
joo (joo) added a comment.Dec 2 2021, 6:47 AM
Thank you! It works properly on 9sec9b4d6e33!
Poyo (poyoiamayoyo) added a subscriber: Poyo (poyoiamayoyo).May 31 2022, 7:30 AM
Poyo (poyoiamayoyo) added a comment.May 31 2022, 7:36 AM
Hey @YimingWu (NicksBest) ,
I encounter the same problem with the line art - I'm already using 3.1.2
Operating system: Windows 10
MEMORY: 32GB RAM
Short description of the error
The line art of Blender 3.1.2 is Flickering and some of it is invisible - it's very hard to edit since any small movement will almost make the blender unworkable. I'm not 100% that this is the same problem, but it does have the same characteristics
Is there anything you need from me?
Kind regards,
Poyo
YimingWu (NicksBest) added a comment.May 31 2022, 8:04 AM
Hi @Poyo (poyoiamayoyo) ! Do you have a file set up that I can take a look?
Poyo (poyoiamayoyo) added a comment.May 31 2022, 6:23 PM
Hey @YimingWu (NicksBest),
Thank you for your quick response, below is the file. Intentionally didn't put the materials since it's too large.
Please let us know what you find out :)
Poyo
