Maniphest T93591
Geometry Nodes: Random Integer min and max values half as frequent
Closed, Resolved
Hans Goudey (HooglyBoogly)
RoyTheKoi
Dec 3 2021, 4:29 AM
  • BF Blender
  • Nodes & Physics
Jesse Yurkovich (deadpin)
RoyTheKoi
Operating system: macOS Big Sur 11.2.3
Graphics card: AMD Radeon Pro 5500M 8 GB
Broken: 3.1.0 Alpha, 88e9e97ee907, master, 2021-11-30
Worked: Unknown
When using the random value node set to integer mode, the probability of each integer value appearing is not the same. Instead, the min and max values appear approximately half as frequently as other values.
  1. Open the attached blend file.
  2. In the spreadsheet editor change the value on the row filter to see the amount of each random integer. Notice that the quantity of min and max values is around half that of other values.
Revisions and Commits
rB Blender
D13474
D13474
Related Objects
Mentioned In
T93479: 3.0 Potential candidates for corrective releases
Mentioned Here
rB88e9e97ee907: Geometry Nodes: Add Point Count to Spline Length Node
RoyTheKoi created this task.Dec 3 2021, 4:29 AM
RoyTheKoi updated the task description.Dec 3 2021, 4:32 AM
Jesse Yurkovich (deadpin) changed the task status from Needs Triage to Confirmed.Dec 3 2021, 5:03 AM
Jesse Yurkovich (deadpin) added a project: Nodes & Physics.
Jesse Yurkovich (deadpin) added a subscriber: Jesse Yurkovich (deadpin).
Confirmed here as well. This is due to how the node rounds the random floating point number to an integer using floorf(value + 0.5f)
Hans Goudey (HooglyBoogly) closed this task as Resolved by committing rBf886f293550c: Fix T93591: Random Value node first and last value proportion.Dec 10 2021, 4:35 PM
Hans Goudey (HooglyBoogly) claimed this task.
Hans Goudey (HooglyBoogly) added a commit: rBf886f293550c: Fix T93591: Random Value node first and last value proportion.
Philipp Oeser (lichtwerk) added a commit: rB99efb9544138: Fix T93591: Random Value node first and last value proportion.Jan 11 2022, 9:00 AM
