Maniphest T93620
Cycles X broke OptiX memory pooling via NVLink
Closed, Resolved
Philipp Oeser (lichtwerk)
Rincewind (Rincewind3D)
Dec 3 2021, 11:56 PM
  • BF Blender
  • Cycles
  • Render & Cycles
Jesse Yurkovich (deadpin)
Patrick Mours (pmoursnv)
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Distribute memory across devies (Optix ) is in Blender 3.0 broken
  • Open the attached blend file in Blender 3.0.
  • Ensure that you have 2x RTX 2080TI with NVLink and enable "Distribute memory across devices" in OptiX
  • Click on render
  • Render will crash with this error:
Failed to build OptiX acceleration structure
OPTIX_ERROR_INVALID_VALUE in optixAccelBuild(context, 0, &options, &build_input, 1, temp_mem.device_pointer, sizes.tempSizeInBytes, out_data.device_pointer, sizes.outputSizeInBytes, &out_handle, use_fast_trace_bvh ? &compacted_size_prop : 0, use_fast_trace_bvh ? 1 : 0) (C:\Users\blender\git\blender-v300\blender.git\intern\cycles\device\optix\device_impl.cpp:1066)OPTIX_ERROR_INVALID_VALUE in optixAccelBuild(context, 0, &options, &build_input, 1, temp_mem.device_pointer, sizes.tempSizeInBytes, out_data.device_pointer, sizes.outputSizeInBytes, &out_handle, use_fast_trace_bvh ? &compacted_size_prop : 0, use_fast_trace_bvh ? 1 : 0) (C:\Users\blender\git\blender-v300\blender.git\intern\cycles\device\optix\device_impl.cpp:1066)
Additional informations
  • "Distribute memory across devices" is working in CUDA mode (Blender 3.0)
  • "Distribute memory across devices" in OptiX is working in Blender 2.93 - you can open the attached file in 2.93 and will see it's rendering.
  • The attached file requires 17GB VRAM in OptiX in Blender 2.93. If you have 2x RTX 3090 this bug can be maybe also reproduced by increasing the required VRAM over 24GB, just duplicate some Suzsannes. I was only able to test it on 2x RTX 2080ti because my lack of 3090s ;)
Thank you for your help
Revisions and Commits
rC Cycles
D13488
rB Blender
D13488
D13488
Related Objects
Mentioned In
T94530: optix error when trying to render
T93479: 3.0 Potential candidates for corrective releases
Mentioned Here
rBe14f8c2dd765: Cycles: Reintroduce device-only memory handling that got lost in Cycles X merge
Rincewind (Rincewind3D) created this task.Dec 3 2021, 11:56 PM
Rincewind (Rincewind3D) added projects: Cycles, Render & Cycles.Dec 3 2021, 11:59 PM
Rincewind (Rincewind3D) updated the task description.
Rincewind (Rincewind3D) added a subscriber: Patrick Mours (pmoursnv).EditedDec 4 2021, 12:38 AM
@Patrick Mours (pmoursnv)
Maybe you can take a look on this issue?
Rincewind (Rincewind3D) added a subscriber: Patrick M. Jordan (patrick).EditedDec 6 2021, 6:47 PM
Hey,
thank you for the quick PR for this issue. But does your PR really fix this issue?
The problem is not getting out of memory, the problem is that the shared memory of two cards via NVLink is not working in OptiX. Memory size should be fine, if memory pooling would work like in 2.93.
Rincewind (Rincewind3D) removed a subscriber: Patrick M. Jordan (patrick).Dec 6 2021, 6:52 PM
Patrick Mours (pmoursnv) added a comment.Dec 7 2021, 11:42 AM
The OPTIX_ERROR_INVALID_VALUE you are seeing is happening because of an out of memory (you can verify this is the log, with "--debug-cycles"). Likely this is the case because BVH builds are happening in parallel, which quickly exhausts available memory because of temporary build memory required (and has some additional known quirks when memory pooling is active), rather than serialized which does not suffer from that problem. That was fixed before (and is in 2.93), but the fix got lost in the Cycles X merge (and thus is not in 3.0), hence why 3.0 behaves differently. The rest of the pooled memory implementation has not changed.
Patrick Mours (pmoursnv) added a commit: rBe14f8c2dd765: Cycles: Reintroduce device-only memory handling that got lost in Cycles X merge.Dec 7 2021, 6:50 PM
Jesse Yurkovich (deadpin) changed the task status from Needs Triage to Needs Information from User.Dec 24 2021, 3:26 AM
Jesse Yurkovich (deadpin) added a subscriber: Jesse Yurkovich (deadpin).
@Rincewind (Rincewind3D) Are you able to try out a 3.1 build to double-check that the issue is fixed?
Rincewind (Rincewind3D) added a comment.Dec 24 2021, 11:06 AM
@Jesse Yurkovich (deadpin)
Yes, it working fine in 3.1.
Tested in:
Blender 3.1.0 - Alpha
December 24, 02:24:18 - 35bd6fe993a1
Philipp Oeser (lichtwerk) closed this task as Resolved.Dec 28 2021, 1:05 PM
Philipp Oeser (lichtwerk) mentioned this in T93479: 3.0 Potential candidates for corrective releases.
So since rBe14f8c2dd765: Cycles: Reintroduce device-only memory handling that got lost in Cycles X merge is in 3.1 master, and it is also on the list T93479: 3.0 Potential candidates for corrective releases, will close.
Philipp Oeser (lichtwerk) added a commit: rB3d5dbc1c4490: Cycles: Reintroduce device-only memory handling that got lost in Cycles X merge.Jan 11 2022, 10:38 AM
Brecht Van Lommel (brecht) added a commit: rC2885c4c2c980: Reintroduce device-only memory handling that got lost in Cycles X merge.Jan 27 2022, 11:37 PM
Pratik Borhade (PratikPB2123) mentioned this in T94530: optix error when trying to render.Apr 27 2022, 7:37 AM
