Maniphest T93644
Beveled curves disappear in hair particle system
Closed, Duplicate
None
Gandalf Bartholomäus (Gandarufu)
Dec 4 2021, 11:53 AM
  • BF Blender
  • Nodes & Physics
Hans Goudey (HooglyBoogly)
Pratik Borhade (PratikPB2123)
Operating system: Win10 64
Graphics card: Nvidia RTX3070 (497.09)
Broken: 3.0.0 stable release
Worked: LTS 2.93
Caused by rBb9febb54a492: Geometry Nodes: Support modifier on curve objects
Beveled curves disappear as hair particles.
As long as curves don't have any bevel applied, they show up as objects or collections in a hair particle system.
As soon as you apply any sort of bevel, they disappear.
  • Create curve
  • Create hair particle system and select that curve as render object
  • Edit bevel of curve
or
  • Open .blend file
  • Change bevel depth (hair particles will disappear)
Test File:
Related Objects
Mentioned In
T94996: Hair particles from curve objects and bevel them
Mentioned Here
Gandalf Bartholomäus (Gandarufu) created this task.Dec 4 2021, 11:53 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Dec 4 2021, 1:48 PM
Pratik Borhade (PratikPB2123) updated the task description.Dec 4 2021, 2:44 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.EditedDec 4 2021, 2:46 PM
Pratik Borhade (PratikPB2123) added a project: Nodes & Physics.
Pratik Borhade (PratikPB2123) added a subscriber: Hans Goudey (HooglyBoogly).
Hi, thanks for the report. This has been introduced by the commit rBb9febb54a492: Geometry Nodes: Support modifier on curve objects
cc @Hans Goudey (HooglyBoogly)
Will change priority to high. Feel free to reset the priority :)
Pratik Borhade (PratikPB2123) triaged this task as High priority.Dec 4 2021, 2:47 PM
Hans Goudey (HooglyBoogly) added a comment.Dec 4 2021, 2:54 PM
Thanks for the report. Unfortunately this is a known issue in Blender 3.0. The particle system is end of life, so we're planning to focus on replacing it rather than hacking a fix together that might break other areas anyway.
Hans Goudey (HooglyBoogly) closed this task as a duplicate of T93159: Particle don't emit curves/text in 3.0 beta .Dec 4 2021, 2:55 PM
