Maniphest T93702
Curve Modifier on mesh objects uses curve before any modifications on target curve
Closed, Archived
None
Nimja (Nimja)
Dec 5 2021, 3:14 PM
  • BF Blender
Hans Goudey (HooglyBoogly)
Nimja (Nimja)
Operating system: Windows 10 - Probably irrelevant.
Broken: 3.0.0 (not checked earlier versions).
Worked: (none)
Curve Modifier on mesh objects uses curve before any modifications on target curve, so geometry nodes or other modifiers that change the curve are not reflected in the mesh (which should follow the curve)
See attached blend file for easy example:
  • Bezier Curve, with some subdivision with a "wave" modifier.
  • Cube .1m with loop cuts to follow curve
  • Cube: Add Array modifier and Curve modifier, targeting the bezier curve
Expected result: Mesh follows waved curve.
Actual result: Mesh follows original (unmodified) curve.
This doesn't work with Geometry nodes or any other modifiers that I've tested for the curve.
Nimja (Nimja) created this task.Dec 5 2021, 3:14 PM
Nimja (Nimja) updated the task description.Dec 5 2021, 3:18 PM
Hans Goudey (HooglyBoogly) closed this task as Archived.Dec 5 2021, 10:36 PM
Hans Goudey (HooglyBoogly) added a subscriber: Hans Goudey (HooglyBoogly).
Thanks for the report. This isn't a bug though, just something that Blender's interface doesn't make very clear. In short, the wave modifier doesn't work on curves, so the curve is implicitly converted to a mesh so the modifier can work on it. If you want it to affect the curve, you can toggle this little option in the modifier header:
Geometry nodes is meant to significantly improve this situation, since deformation can work on any geometry type, and because it's much more clear when a curve becomes a mesh.
Nimja (Nimja) added a comment.Dec 5 2021, 11:56 PM
Actually, the Wave Modifier works just fine in 3.0 with curves :) That's not the point. With Geometry nodes the SAME issue persist.
If you APPLY the curve, it updates the mesh.
You can see the curve itself being in a different place than the mesh in the uploaded blend file. I could make an example with Geometry nodes as well, but I was lazy.
