Maniphest T93730
Crashing after render
Closed, Archived
None
don (dbrown7080)
Dec 6 2021, 2:51 AM
  • BF Blender
don (dbrown7080)
Pratik Borhade (PratikPB2123)
Operating system: Windows 10
Graphics card: Nvidia Quadro M2000
Broken: Version 3.0
Worked: Version 2.95
I render a single image, and as soon as I go to close the rendered image, Blender crashes.
don (dbrown7080) created this task.Dec 6 2021, 2:51 AM
don (dbrown7080) added a comment.Dec 6 2021, 3:08 AM
Sorry, the last working version was 2.93.6
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Dec 6 2021, 6:59 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Hi, thanks for reporting. This report does not contain all the requested information, which is required for us to investigate the issue.
Are you able to reproduce crash with specific .blend file? Could you please also attach that file as well?
May be similar to T93641: blender3.0.0 f1cca3055776 crashing when render is stopped before finishing
Please provide crash logs: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#crash-log
(A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports)
don (dbrown7080) added a comment.Dec 6 2021, 3:17 PM
I'll have to reinstall 3.0 and redo the project. It crashed so many times I reverted to the older version.
don (dbrown7080) added a comment.Dec 6 2021, 3:47 PM
Here are the debug files.
don (dbrown7080) added a comment.Dec 9 2021, 7:18 PM
Have you checked the debug files? I gave you all the information I have. It kept doing it when I closed the rendered page, even if I waited for it to finish rendering, which I usually do.
Pratik Borhade (PratikPB2123) added a comment.Dec 10 2021, 7:06 AM
Hi @don (dbrown7080) , provided files are not correct. Please do the following:
  • Open blender_debug_log.cmd (located in the same directory where blender.exe is)
  • Reproduce the crash.
  • Windows explorer will open with two files (add those files here)
  • Open blender_debug_output.txt
  • At the very bottom you will find the path for blender.crash.txt
  • Then also the file blender.crash.txt
I suspect this as a duplicate of T93855: Cycles crash with edit mode and simultaneous viewport and final render
Is that a case for you?
Pratik Borhade (PratikPB2123) closed this task as Archived.Dec 20 2021, 7:15 AM
