Graphics card: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
the object material is not assigned if you use geometry node mesh primitive instance and remesh modifier after
- add geometry nodes to an object
- distribute point on face
- instance mesh primitive on point (like icosphere)
- add realize instance node
- add material (it will be show up)
- add remesh modifier (the material will be unassigned)
it works well if you use as instance an object in scene instead of a mesh primitive inside geometry node
