Maniphest T93866
Blender crashes when bevel edge(CTRL + B, not modifier) + Shade Smooth then press CTRL + Z two more times
Closed, Archived
None
fott (fott)
Dec 8 2021, 3:34 PM
  • BF Blender
  • Modeling
Fen (chemicalcrux)
fott (fott)
Garek (Garek)
Richard Antalik (ISS)
Operating system: Windows 10 Pro 21H1 Windows Feature Experience Pack 120.2212.3920.0
Graphics card: RTX 2070
Blender 3.0.0 - Stable
December 08, 02:18:27 - f1cca3055776
I created a cube, then bevel one of edges, then shade smooth this cube and when i press ctrl + z two more times blender crushes
sorry for my english, blender crash log and startup file also attached
Related Objects
Mentioned Here
rBa040d2a93a7d: Fix T90592: Incorrect scrollbar range with backdrop
rBf1cca3055776: Blender 3.0 - version bump -> release
fott (fott) created this task.Dec 8 2021, 3:34 PM
fott (fott) changed the task status from Needs Triage to Needs Information from Developers.Dec 8 2021, 3:38 PM
fott (fott) added a project: Modeling.
Garek (Garek) changed the task status from Needs Information from Developers to Needs Triage.Dec 9 2021, 10:34 AM
Garek (Garek) added a subscriber: Garek (Garek).
Please do not change status by yourself when reporting.
I myself can't confirm on a040d2a93a7d (can't use newer version) or 2.92. It'll be useful if you could test it on latest alpha version that can be found here:
https://builder.blender.org/download/daily/
fott (fott) added a comment.Dec 9 2021, 12:30 PM
I need download 3.1.0 alpha, right?
Garek (Garek) added a comment.Dec 9 2021, 12:52 PM
Yes
fott (fott) added a comment.Dec 9 2021, 3:42 PM
same problem with blender 3.1.0
when i used blender 3.0(4 december version), i didn't have this problem
fott (fott) added a comment.Dec 9 2021, 3:45 PM
i noticed that whatever i do with cube, when i press CTRL + Z two more times its crushes
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Dec 11 2021, 12:37 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Also can't reproduce this. Run blender_debug_log.cmd in alpha build folder and upload created files after crash.
In provided file there are no objects, your steps are incomplete. I only add cube is missing?
fott (fott) added a comment.Dec 11 2021, 8:59 AM
Idk, when i run blender with blender_debug_log.cmd its works fine(without any problems)!
Its my startup file, you should follow these steps:
Richard Antalik (ISS) added a comment.Dec 12 2021, 10:34 PM
That's very strange.
Can you check if you click on File > Defaults > Load Factory Settings and redo steps to reproduce? Also check if this happens with latest alpha build from https://builder.blender.org/download/daily/.
fott (fott) added a comment.Dec 13 2021, 1:10 PM
I got debug log from blender_debug_log.cmd
Richard Antalik (ISS) added a comment.Dec 13 2021, 7:33 PM
From logs I suspect this could be caused by one of addons, Check if this happens when you click on File > Defaults > Load Factory Settings
Fen (chemicalcrux) closed this task as Archived.Dec 30 2021, 7:06 PM
Fen (chemicalcrux) added a subscriber: Fen (chemicalcrux).
I was not able to replicate this on the 3.0 release (even with every bundled add-on enabled, in case one was relevant).
Thanks again for the report. If the problem persists, please open a new report after taking the requested actions.
