Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.96
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Color input on geometry nodes modifier causes console to print "Could not find button with matching property to decorate (NodesModifier.Input_#)" whenever UI updates.
Update: The vertical value slider (in the geometry node modifier color input's popup) also does not appear to work, slider is stuck and the value just jumps between minimum and maximum values.
I'm assuming it's related.
From appended blend:
Load file and look at console
Attempt to adjust the vertical value slider in the geometry nodes modifier color input's popup
Full steps:
Add geometry nodes modifier to an object
Give it a color input
Make sure the modifier properties are on screen
Check console
