Maniphest T93997
Weight error export - Error on deform
Closed, Archived
None
thiago meteles (meteles)
Dec 12 2021, 7:21 PM
  • Add-ons (Community)
Omar Emara (OmarSquircleArt)
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Addon Information
Name: FBX format (4, 27, 0)
Author: Campbell Barton, Bastien Montagne, Jens Restemeier
deform error on fbx
deform error, see images.
Steps
original animation on blender (baked, only deform bones)
Deform error on export fbx on artstation (run animation) ( https://sketchfab.com/3d-models/raven-witch-7b7b7e93a3ee4f7889429d058235ec23){F12734799}
same fbx import on blender test, same error
export settings
on blend file only cloak and skull for test.
thiago meteles (meteles) created this task.Dec 12 2021, 7:21 PM
thiago meteles (meteles) updated the task description.
thiago meteles (meteles) updated the task description.Dec 12 2021, 7:23 PM
thiago meteles (meteles) updated the task description.Dec 12 2021, 8:08 PM
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 23 2022, 9:40 AM
Omar Emara (OmarSquircleArt) added a subscriber: Omar Emara (OmarSquircleArt).
Can you attach this file here in order to test this? Did you try importing again into Blender and checking if the issue is also visible in Blender?
Omar Emara (OmarSquircleArt) added a comment.Apr 5 2022, 11:49 AM
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
thiago meteles (meteles) added a comment.EditedApr 22 2022, 9:38 AM
I exported the fbx with the animations in actions, imported this fbx in sketchfab and in blender and the same error occurred.
New file on blender and import fbx - same deformation error
Omar Emara (OmarSquircleArt) added a comment.May 24 2022, 2:04 PM
Can you attach the file here? As it is no longer available in the link.
Omar Emara (OmarSquircleArt) closed this task as Archived.Jun 8 2022, 11:25 AM
