Maniphest T94098
Reset to default value on select linked delimiter will cause undo almost everything to original state
Closed, Duplicate
None
Boqian Jiang (iouzzr)
Dec 15 2021, 8:57 AM
  • BF Blender
Pratik Borhade (PratikPB2123)
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Worked: 2.93
Reset to default value on select linked delimiter will cause undo almost everything to original state.
  1. use default startup cube, deselect it, select it, deselect it, select it, make something in the undo history
  2. go to edit mode
  3. select any vertex
  4. press Ctrl L, which is shortcut for select linked
  5. in the adjust last operation window, hover mouse onto Delimit->Material, right click and select Reset to default value, reset twice
  6. bug appears, force you undo to original state on the undo history
Boqian Jiang (iouzzr) created this task.Dec 15 2021, 8:57 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Dec 15 2021, 9:37 AM
Hi, thanks for the report. This is the same problem as mentioned in T93629: Regression: Reset To Default Value undoing everything when applied twice in the same menu.
Will merge your report in T93629.
