Maniphest T94130
Blender Camera Background Video Crash
Closed, Duplicate
None
Blender Bach (blenderbach)
Dec 15 2021, 10:56 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Pratik Borhade (PratikPB2123)
Operating system: Windows 10
Graphics card: NVIDIA GTX 1050
Broken: Blender 3.0
Worked: 3.0 Alpha Daily Build Probably
Switching from Rendered View to Solid View in EEVEE while playing background reference video in Camera View, crashes Blender.
Start with a new default scene. Go to Camera View, and then load a Reference Video using Background Images in the Camera Options Panel. Finally, play the video, in Rendered View in EEVEE, when you switch to solid view, it will crash Blender immediately!
Blender Bach (blenderbach) created this task.Dec 15 2021, 10:56 PM
Pratik Borhade (PratikPB2123) updated the task description.Dec 16 2021, 10:46 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Dec 16 2021, 10:52 AM
Hi, Thanks for the report. Can not reproduce here on master and 3.0.0.
Please send log files generated after the crash: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#crash-log
Also please check if you can reproduce crash with factory settings: FileDefaultsLoad Factory Settings
Blender Bach (blenderbach) added a comment.EditedDec 16 2021, 6:12 PM
Here are the two files...
Pratik Borhade (PratikPB2123) added a comment.Dec 17 2021, 2:52 PM
Hi, thanks for sending crash logs.
Does that work for you?
May be I am trying to repro in a wrong manner. Can you please check the video?
Blender Bach (blenderbach) added a comment.EditedDec 17 2021, 11:09 PM
You must start playing it, and while the video is running, switch between solid to rendered.
You see, you loaded up the video, and then just started switching between solid and rendered. I do that too, and it doesn't crash
But if I press play on the animation timeline, while the video is running, if I switch between solid and rendered, it crashes.
Blender Bach (blenderbach) added a comment.Dec 18 2021, 5:37 PM
Here's a Video I attached showing the crash in action.
Pratik Borhade (PratikPB2123) added a comment.Dec 19 2021, 8:57 PM
Hi, this is something which I can not reproduce frequently. 3.0.0 crashed for a couple of times but build on master branch(3.1.0) works fine here.
@Blender Bach (blenderbach), any luck with 3.1.0? Still crashing?: https://builder.blender.org/download/daily
Pratik Borhade (PratikPB2123) added a comment.Dec 20 2021, 12:06 PM
Similar problem has been reported and closed recently: T94266: Crash with Movieclip background in Camera view
(Both appears to be same issue)
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Dec 20 2021, 12:22 PM
This is indeed fixed, see T94266: Crash with Movieclip background in Camera view.
Will merge reports, see the other report where to get a working build (but of course feel free to comment again if issues persist).
Philipp Oeser (lichtwerk) closed this task as a duplicate of T94266: Crash with Movieclip background in Camera view.Dec 20 2021, 12:23 PM
Blender Bach (blenderbach) added a comment.Dec 20 2021, 4:59 PM
How is this even possible? Blender 3.0 is a stable version, yet Blender 3.1 is more stable than the stable version? 😂
Philipp Oeser (lichtwerk) added a comment.Dec 20 2021, 9:05 PM
@Blender Bach (blenderbach) : there will probably be a 3.0.1, see T93479: 3.0 Potential candidates for corrective releases
Blender Bach (blenderbach) added a comment.EditedDec 20 2021, 9:24 PM
You're all fired! 😂
Just kidding!
Thanks for the information!
