Maniphest T94131
Blender crashes when linking curve modifier in edit mode with vertex group
Closed, Duplicate
None
Miles Holt (milesholt)
Dec 15 2021, 11:20 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
When linking a mesh's vertex group to a curve as an influence, and with 'Edit Mode' and 'On Cage' checked, after going into Edit Mode the application crashes.
Add a plane
Add a bezier curve
Select the plane, then create vertex group and assign some vertices
In Modifiers, add a Curve Modifier
Link plane to curve
Select vertex group as influence
Select 'Display Modifier in Edit Mode' and 'On Cage'
Tab and go into edit mode
Miles Holt (milesholt) created this task.Dec 15 2021, 11:20 PM
Miles Holt (milesholt) updated the task description.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Dec 16 2021, 1:31 PM
This is already fixed by rB0e52af097f9f: Fix T93611: Curve modifier crash in editmode in certain situations
It is also on the list T93479: 3.0 Potential candidates for corrective releases.
Will merge into T93611, thx reporting anyways!
