Maniphest T94261
Wrong Material Assigned to New Geometry from Mesh Boolean Node
Closed, Duplicate
None
Chris Gauthier (themaniacalartist)
Dec 20 2021, 12:20 AM
  • BF Blender
Philipp Oeser (lichtwerk)
Operating system: Windows 10
Graphics card: Nvidia GTX 1060
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) 3.0.0
Worked: (newest version of Blender that worked as expected) N/A (uses node that debuted in 3.0)
When I use the Set Material node on a given piece of geometry and then wire the output into the second input socket of a Mesh Boolean node with the mode set to "Difference", the new geometry generated by the Mesh Boolean node is given whatever material is in the second slot in the object's Material Shelf, rather than reflecting the material specified by the Set Material node.
Create at least two materials in addition to the existing default material on the object. Create a new Geometry Nodes modifier on the object. Insert a Mesh Boolean node onto the existing noodle with the mode set to "Difference." Next, create a Mesh Primitive node (any), and wire the geometry from it through a Set Material node. Specify a material, and it should work fine on the geometry itself. However, if you now wire that into the second input socket of the Mesh Boolean node, you will notice that, regardless of what Material you specify in the Set Material node (as long as you at least specify something), the new geometry that is generated always shows whatever Material is currently in the second slot in the object's Material Shelf. Attached is a demo blend file.
Chris Gauthier (themaniacalartist) created this task.Dec 20 2021, 12:20 AM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Dec 20 2021, 11:35 AM
The Boolean node is known to handle materials correctly, see also T93272: mesh boolean node breaks material assignments., will merge these reports.
Philipp Oeser (lichtwerk) closed this task as a duplicate of T93272: mesh boolean node breaks material assignments..Dec 20 2021, 11:35 AM
