version: 3.1.0 Alpha (rev 4f48b2992bd)
platform: Windows10 19043.1415
With Microsoft Pinyin IME, Inputting "/" key become a letter "/、" not "、" like below in text edit.
ng:
ok:
| Takahiro Shizuki (sntulix) |
| Takahiro Shizuki (sntulix) | |
| Dec 28 2021, 9:58 AM |
| Harley Acheson (harley) |
| Richard Antalik (ISS) |
| Yuro (Yuro) |
| 炎臻 (PrettyFireNOI7) |
ng:
| rB Blender | |||
| D13771 | rB57bea57f5ec6 Fix T94434: Windows IME Pinyin Forward Slash | ||
I may be found the point to fix.
diff --git a/intern/ghost/intern/GHOST_ImeWin32.cpp b/intern/ghost/intern/GHOST_ImeWin32.cpp
index 47b5f5688df..26a019e6762 100644
--- a/intern/ghost/intern/GHOST_ImeWin32.cpp
+++ b/intern/ghost/intern/GHOST_ImeWin32.cpp
@@ -98,6 +98,7 @@ bool GHOST_ImeWin32::IsEnglishMode()
bool GHOST_ImeWin32::IsImeKeyEvent(char ascii)
+ printf("key code: %x\n", ascii);
if (!(IsEnglishMode())) {
/* In Chinese, Japanese, Korean, all alpha keys are processed by IME. */
if ((ascii >= 'A' && ascii <= 'Z') || (ascii >= 'a' && ascii <= 'z')) {
@@ -106,7 +107,7 @@ bool GHOST_ImeWin32::IsImeKeyEvent(char ascii)
if (IsLanguage(IMELANG_JAPANESE) && (ascii >= ' ' && ascii <= '~')) {
return true;
- else if (IsLanguage(IMELANG_CHINESE) && ascii && strchr("!\"$'(),.:;<>?[\\]^_`", ascii)) {
+ else if (IsLanguage(IMELANG_CHINESE) && ascii && strchr("!\"$'(),.:;<>?[\\]^_`/", ascii)) {
return true;
}A screenshot of above build.
The patched build.
https://www.futuregadget.com/file/blender-T94434-fixing-build-20211228.zip
Can confirm.
When outside of Blender and entering Pinyin, the three keys to the right of "M" give me ,。、
But inside Blender those same keys give me ,。/、
@Takahiro Shizuki (sntulix) - You should to create a new new diff and when you submit it give it a description like "Fix T94434: Windows IME Pinyin Forward Slash". I'll look out for it and edit if needed. Or if you need any other help let me know.
I think it because Microsoft Pinyin IME is a little different?
I can get the same results in other software.
I don't know why, but I don't seem to be able to confirm this bug. When I use Microsoft input IME in other software, \ = 、
Ah, I can confirm this now, I'm OK because I enable this before:
I see, thank you.
I did it. D13771
Hi.
OK.
Thank you.
And, I checked with Blender patched the diff above with the patterns Microsoft Pinyin compatible mode is enable and disable both.
