Maniphest T94442
Extruding first vertex of a spline with GN modifier enabled causes a crash
Closed, ResolvedBUG
Hans Goudey (HooglyBoogly)
slowburn (slowburn)
Dec 28 2021, 5:38 PM
  • BF Blender
  • Nodes & Physics
  • Geometry Nodes
slowburn (slowburn)
Graphics card: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.09
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Worked: not sure
I have a file with a simple Geometry Nodes modifier on a curve and extruding first vertex of a spline (based on direction) causes Blender to crash. It doesn't happen 100% of the time, but after a couple of extrudes it eventually crashes. Also it only happens if vertex has handle type set to Vector or spline type is Poly.
  • Use the provided file
  • Extrude first vertex (one on the top in the viewport) on either of the curves
  • Repeat until Blender crashes
Revisions and Commits
rB Blender
slowburn (slowburn) created this task.Dec 28 2021, 5:38 PM
Hans Goudey (HooglyBoogly) changed the task status from Needs Triage to Confirmed.Dec 28 2021, 7:17 PM
Hans Goudey (HooglyBoogly) claimed this task.
Hans Goudey (HooglyBoogly) changed the subtype of this task from "Report" to "Bug".
Hans Goudey (HooglyBoogly) added projects: Nodes & Physics, Geometry Nodes.
Hans Goudey (HooglyBoogly) added a subscriber: Hans Goudey (HooglyBoogly).
Thanks for the report. I can confirm the crash and I've found a fix.
Hans Goudey (HooglyBoogly) closed this task as Resolved by committing rB4cbcfd22f5d2: Fix T94442: Trim curve node can crash with duplicate point.Dec 28 2021, 7:22 PM
Hans Goudey (HooglyBoogly) added a commit: rB4cbcfd22f5d2: Fix T94442: Trim curve node can crash with duplicate point.
Philipp Oeser (lichtwerk) added a commit: rB512014f04216: Fix T94442: Trim curve node can crash with duplicate point.Jan 11 2022, 10:38 AM
