Maniphest T94504
"Jump To Keyframe" not registering as its own separate Undo/Redo step
Closed, Duplicate
None
Matthew Gafford (AFoxInSpace)
Dec 30 2021, 5:29 PM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: Win10
Graphics card: rtx3070
Broken: 3.0, 2.9, 2.83
Worked: N/A
When using the function Jump To Keyframe and then immediately drawing a Grease Pencil stroke afterward, pressing Undo undoes the stroke, but also undoes the keyframe jump, even though you're still on the same frame.
You then have to click the timeline to get Blender to realize your other objects are on the wrong frame.
Steps to reproduce:
  1. Open file It will already be in draw mode.
  1. Press "Jump to Next Keyframe" on the timeline a few times, get to keyframe 7
  1. Draw a stroke and Undo it.
You will notice it Undoes the stroke you drew, but also pushes the cube back to frame 5, even though you're still on frame 7. Click on the current frame in the timeline, and you will see the cube snap to where it's supposed to be. Pressing Undo should only undo the stroke at that point, not push other animated objects out of timeline sync.
Here's a YouTube video explaining further:
https://www.youtube.com/watch?v=pt97DNFl1fo
Matthew Gafford (AFoxInSpace) created this task.Dec 30 2021, 5:29 PM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Dec 31 2021, 8:11 AM
Pratik Borhade (PratikPB2123) added a comment.EditedDec 31 2021, 8:34 AM
Hi Matthew, thanks for the report. Can reproduce.
Looks same as described in: T66913: Issue with Undoing after using next/previous keyframe shortcut.
Undo snaps back to the previous keyframe in both reports (and playhead will be at same place)
I think its safe to merge your report into T66913
Feel free to comment or reopen if issue is different and not same as T66913 (I might have misunderstood the issue)
Pratik Borhade (PratikPB2123) closed this task as a duplicate of T66913: Issue with Undoing after using next/previous keyframe shortcut..Dec 31 2021, 8:34 AM
