Maniphest T94530
optix error when trying to render
Closed, Archived
None
hasan (sosis)
Dec 31 2021, 12:03 PM
  • BF Blender
Alaska (Alaska)
hasan (sosis)
Pratik Borhade (PratikPB2123)
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
optix error while trying to render
when i try to render with optix i get the error
OPTIX_ERROR_INVALID_VALUE in optixAccelBuild(context, 0, &options, &build_input, 1, temp_mem.device_pointer, sizes.tempSizeInBytes, out_data.device_pointer, sizes.outputSizeInBytes, &out_handle, use_fast_trace_bvh ? &compacted_size_prop : 0, use_fast_trace_bvh ? 1 : 0) (C:\Users\blender\git\blender-v300\blender.git\intern\cycles\device\optix\device_impl.cpp:1066)
but when i use cuda or cpu there's no problem
hasan (sosis) created this task.Dec 31 2021, 12:03 PM
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Dec 31 2021, 9:08 PM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Does this happen with a specific scene or every scene?
If it happens with a specific scene, it would be helpful if you could share the scene with us.
If it happens with every scene, then I would recommend updating or re-installing your GPU drivers.
Link to download latest GPU drivers: https://www.nvidia.com/Download/index.aspx
Link to find older GPU drivers such as 472.12, the one you're currently using: https://www.nvidia.com/Download/Find.aspx?lang=en-us
hasan (sosis) added a comment.Jan 3 2022, 11:17 AM
actually it only happens when i try to use rendered view but when i hit f12 it renders without problem...
and in the rendered view it only works if i hide most of the objects i have...
Alaska (Alaska) added a comment.EditedJan 3 2022, 12:40 PM
Based on your comment, it seems the issue might be related to the scene you're rendering. Are you able to provide us with the .blend file you're experiencing issues with?
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).Apr 27 2022, 7:37 AM
Appears to be fixed already: T93620: Cycles X broke OptiX memory pooling via NVLink
@hasan (sosis) hi, can you download and test in latest builds from buildbot: https://builder.blender.org/download/daily
Pratik Borhade (PratikPB2123) closed this task as Archived.May 11 2022, 7:57 PM
Both reports looks identical to me. So I assume issue has been fixed with T93620.
Also- No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed.
