Maniphest T94568
Rendered image disappears if rendered with tiles
Closed, Archived
None
Maurizio Ferraris (ziomau10)
Jan 2 2022, 10:45 AM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
In case the rendered image is to large and rendered with tiles, and the end of last tile the image disappears, and cannot be saved anymore
Load the default cube, switch to cycles, and GPU processing. In "output properties", "Format" select "%" and set it to 400%. Then render (F12)
The image is rendered using tiles (12 in my case)
After the last tile, the image disappears.
On the consol log there are a bunch of error like:
E0102 10:15:30.189354 14820 tile.cpp:468] Error opening tile file: Could not open "C:\Windows\Temp\blender_a21072\cycles-tile-buffer-9540-1314889624184-102-0.exr" (No such file or directory)
Error writing tile to file
Maurizio Ferraris (ziomau10) created this task.Jan 2 2022, 10:45 AM
Maurizio Ferraris (ziomau10) renamed this task from Rendered image disappears if endered with tiles to Rendered image disappears if rendered with tiles.Jan 2 2022, 10:58 AM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jan 4 2022, 11:39 AM
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Hi, thanks for the report. Did you change the Temporary Files directory from preferences?
Are you able to reproduce with factory preferences?: EditPreferencesSave & Load (3 horizontal lines)Load Factory preferences
Similar issue got reported recently (probably the same case for you): T93727: Changing temporary directory results in errors with tiles while rendering in Cycles
Maurizio Ferraris (ziomau10) added a comment.Jan 4 2022, 12:49 PM
I did not change anything recently, but I normally inherit settings from previous Blender versions, and indeed originally (V2.7xxx) I changed the temp folder to "C:\Windows\Temp".
Probably this folder now have access restrictions and causes the problem.
I changed now to "C:\Users\<user>\temp" and seems to work ok.
Thank you.
By the way, I don't know if this is related, but when I first tried to change the default Temp folder I first right clicked on the field and then "return to default settings".
At that point Blender badly chrashed and I coudn't restart it until a new PC reboot.
I eventually continue to investigate, and open a new task in case.
Thanks for the good job
Regards.
Pratik Borhade (PratikPB2123) added a comment.EditedJan 5 2022, 7:59 AM
I first tried to change the default Temp folder I first right clicked on the field and then "return to default settings". At that point Blender badly crashed
Hi, I would suggest to submit a fresh report for it
Don't think there are restrictions for any specific folder. Try to save preferences after changing the temp file path, then reload blender. This won't give you any error when rendering with tiles.
Does that work for you?
Pratik Borhade (PratikPB2123) added a comment.Jan 11 2022, 6:43 AM
Hi @Maurizio Ferraris (ziomau10) , are you able to reproduce on recent 3.1.0 build?: https://builder.blender.org/download/daily
Similar problem(T93727) got fixed yesterday
Pratik Borhade (PratikPB2123) closed this task as Archived.Jan 18 2022, 4:10 PM
