Maniphest T94708
New-file causes Python assert with negative reference count
Closed, Resolved
Jan 7 2022, 7:41 AM
  • Python API
When Blender is built against a debug Python library the following steps cause a negative reference count and asserts.
This can be redone with the following steps:
  • Run Blender with factory settings.
  • Press W once (to set the circle select tool).
  • Ctrl-N, Enter (to make a new file).
Blender exits with the following error.
source/blender/python/intern/bpy_rna_callback.c:267: _Py_NegativeRefcount: Assertion failed: object has negative ref count
Enable tracemalloc to get the memory block allocation traceback
object address  : 0x7fda4ad5dcc0
object refcount : -1
object type     : 0x55a5d0f754a0
object type name: tuple
object repr     : <refcnt -1 at 0x7fda4ad5dcc0>
Fatal Python error: _PyObject_AssertFailed: _PyObject_AssertFailed
Python runtime state: initialized
Current thread 0x00007fda712548c0 (most recent call first):
  File "/src/cmake_debug/bin/3.1/scripts/startup/bl_ui/space_toolsystem_common.py", line 1073 in _activate_by_item
  File "/src/cmake_debug/bin/3.1/scripts/startup/bl_ui/space_toolsystem_common.py", line 1091 in activate_by_id
  File "/src/cmake_debug/bin/3.1/scripts/startup/bl_operators/wm.py", line 2119 in execute
Extension modules: bpy.props, bpy.app.icons, bpy.app.timers, bpy.utils.units, bpy.types, mathutils.geometry, mathutils.interpolate, mathutils.noise, mathutils, idprop, gpu.capabilities, gpu.matrix, gpu.platform, gpu.select, gpu.shader, gpu.state, gpu.texture (total: 17)
Reporting this for reference.
Revisions and Commits
rB Blender
Campbell Barton (campbellbarton) created this task.Jan 7 2022, 7:41 AM
Campbell Barton (campbellbarton) added a project: Python API.
Campbell Barton (campbellbarton) closed this task as Resolved by committing rBf24854005d86: Fix T94708: negative reference count error with Python API callbacks.Jan 7 2022, 8:06 AM
Campbell Barton (campbellbarton) added a commit: rBf24854005d86: Fix T94708: negative reference count error with Python API callbacks.
Campbell Barton (campbellbarton) mentioned this in T93479: 3.0 Potential candidates for corrective releases.Jan 7 2022, 8:08 AM
Philipp Oeser (lichtwerk) added a commit: rB3b686b823353: Fix T94708: negative reference count error with Python API callbacks.Jan 11 2022, 10:39 AM
