Maniphest T94715
Multiple volumes using same data can cause crash/freeze
Closed, Resolved
Brecht Van Lommel (brecht)
Sebastien Loss (captaincavern)
Jan 7 2022, 2:58 PM
  • BF Blender
  • Nodes & Physics
  • Dependency Graph
Richard Antalik (ISS)
Operating system: macOS-12.1-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64X OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.7.101
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Volume objects with unique data block but pointing on same VDB sequence make blender crashes when scrubbing timeline
No issue when testing with --debug-depsgraph-no-threads
Open file and scrub back and forth for few seconds(around 30 or so)
From scratch:
Open fresh default cube scene. Add a volume object. Import a openVDB sequence ( bake the quick smoke effect for example ).
Duplicate or instance your volume object like five times or more ( two times seems to work ??? ).
Go to volume data panel and make one object or more a single user of this block. ( needed to control the playback of each volume instance for example ).
So now scrub your timeline back and forth a couple of times until freeze blender :)
Revisions and Commits
rB Blender
Sebastien Loss (captaincavern) created this task.Jan 7 2022, 2:58 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 8 2022, 8:13 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
I wasn't able to reproduce this issue. Can you upload sample .blend file so I can double check?
Sebastien Loss (captaincavern) added a comment.EditedJan 11 2022, 3:20 PM
{F12800963}Sure ! Here it is. Just open it with blender 3.0 or current 3.0.1 release candidate ( same problem ) and scratch the timeline a couple of times. Problem don't occurs in 2.93
Richard Antalik (ISS) added a comment.Jan 17 2022, 4:09 PM
Thanks for file, I can reproduce this issue
Not quite sure if this trace is only problem, sometimes I got some memory access exception instead, but sometimes it gets stuck on mutex lock it seems:
 	[External Code]
>	blender.exe!BKE_volume_load(const Volume * volume, const Main * bmain) Line 815	C++
 	blender.exe!BKE_volume_min_max(const Volume * volume, blender::vec_base<float,3> & r_min, blender::vec_base<float,3> & r_max) Line 930	C++
 	blender.exe!GeometrySet::compute_boundbox_without_instances(blender::vec_base<float,3> * r_min, blender::vec_base<float,3> * r_max) Line 201	C++
 	blender.exe!BKE_object_boundbox_calc_from_evaluated_geometry(Object * ob) Line 3921	C++
 	blender.exe!object_sync_boundbox_to_original(Object * object_orig, Object * object_eval) Line 287	C
 	blender.exe!BKE_object_sync_to_original(Depsgraph * depsgraph, Object * object) Line 323	C
 	blender.exe!blender::deg::DepsgraphNodeBuilder::build_object::__l2::<lambda>(Depsgraph * depsgraph) Line 838	C++
 	[External Code]
 	blender.exe!blender::deg::`anonymous namespace'::evaluate_node(const blender::deg::`anonymous-namespace'::DepsgraphEvalState * state, blender::deg::OperationNode * operation_node) Line 120	C++
 	blender.exe!blender::deg::`anonymous namespace'::deg_task_run_func(TaskPool * pool, void * taskdata) Line 132	C++
 	blender.exe!Task::operator()() Line 179	C++
 	blender.exe!tbb::internal::function_task<Task>::execute() Line 1060	C++
 	[External Code]
 	blender.exe!VolumeFileCache::update_for_remove_user(VolumeFileCache::Entry & entry) Line 252	C++
 	blender.exe!VolumeFileCache::remove_user(VolumeFileCache::Entry & entry, const bool tree_user) Line 228	C++
 	blender.exe!VolumeGrid::~VolumeGrid() Line 302	C++
 	[External Code]
 	blender.exe!VolumeGridVector::clear_all() Line 486	C++
 	blender.exe!BKE_volume_unload(Volume * volume) Line 884	C++
 	blender.exe!BKE_volume_eval_geometry(Depsgraph * depsgraph, Volume * volume) Line 1068	C++
 	blender.exe!blender::deg::DepsgraphNodeBuilder::build_object_data_geometry_datablock::__l27::<lambda>(Depsgraph * depsgraph) Line 1616	C++
 	[External Code]
 	[External Code]
 	blender.exe!tbb::task::wait_for_all() Line 821	C++
 	blender.exe!tbb::internal::task_group_base::wait() Line 168	C++
 	blender.exe!tbb_task_pool_work_and_wait(TaskPool * pool) Line 254	C++
 	blender.exe!BLI_task_pool_work_and_wait(TaskPool * pool) Line 501	C++
 	blender.exe!blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph * graph) Line 401	C++
 	blender.exe!deg_flush_updates_and_refresh(blender::deg::Depsgraph * deg_graph) Line 61	C++
 	blender.exe!DEG_evaluate_on_framechange(Depsgraph * graph, float frame) Line 88	C++
 	blender.exe!BKE_scene_graph_update_for_newframe_ex(Depsgraph * depsgraph, const bool clear_recalc) Line 2664	C
 	blender.exe!BKE_scene_graph_update_for_newframe(Depsgraph * depsgraph) Line 2712	C
 	blender.exe!ED_update_for_newframe(Main * bmain, Depsgraph * depsgraph) Line 1729	C
 	blender.exe!screen_animation_step_invoke(bContext * C, wmOperator * UNUSED_op, const wmEvent * event) Line 4755	C
 	blender.exe!wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const bool poll_only, bool use_last_properties) Line 1313	C
 	blender.exe!wm_handler_operator_call(bContext * C, ListBase * handlers, wmEventHandler * handler_base, wmEvent * event, PointerRNA * properties, const unsigned char * kmi_idname) Line 2314	C
 	blender.exe!wm_handlers_do_keymap_with_keymap_handler(bContext * C, wmEvent * event, ListBase * handlers, wmEventHandler_Keymap * handler, wmKeyMap * keymap, const bool do_debug_handler) Line 2667	C
 	blender.exe!wm_handlers_do_intern(bContext * C, wmWindow * win, wmEvent * event, ListBase * handlers) Line 2994	C
 	blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 3129	C
 	blender.exe!wm_event_do_handlers(bContext * C) Line 3725	C
 	blender.exe!WM_main(bContext * C) Line 642	C
 	blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 564	C
 	[External Code]
Richard Antalik (ISS) renamed this task from Make single user on shared volume data sequence freezes blender when scrubbing / play timeline to Multiple volumes using same data can cause crash/freeze.Jan 17 2022, 4:15 PM
Richard Antalik (ISS) changed the task status from Needs Information from User to Confirmed.
Richard Antalik (ISS) updated the task description.
Richard Antalik (ISS) added projects: Nodes & Physics, Dependency Graph.
Brecht Van Lommel (brecht) closed this task as Resolved by committing rBb776c46d2f67: Fix T94715: multiple volumes using the same .vdb causes freeze.Jan 17 2022, 8:42 PM
Brecht Van Lommel (brecht) added a commit: rBb776c46d2f67: Fix T94715: multiple volumes using the same .vdb causes freeze.
Philipp Oeser (lichtwerk) added a commit: rB0039432cfcc5: Fix T94715: multiple volumes using the same .vdb causes freeze.Jan 20 2022, 9:25 PM
