Maniphest T94747
Blender crashes when I try to assign custom thumbnail in asset browser
Closed, Archived
None
Bohdan Tsymbala (efreeti)
Jan 8 2022, 7:04 PM
  • BF Blender
Pratik Borhade (PratikPB2123)
Operating system: macOS (Monterey) 12.1 (21C52)
Graphics card: AMD Radeon Pro 5300M 4 GB
Graphics card: Intel UHD Graphics 630 1536 MB
Broken: 3.0.0 (3.0.0 2021-12-03)
Worked: Was not observed to work
I have a blend file with some assets. I keep this file in a shared asset folder configured as user library folder. I tried to assign the custom thumbnail to one of the assets and blender crashes with below report. I would like for now to not share the file, so if it's possible please use the stack trace to advice for what can be the problem. If absolutely necessary I can figure out a way to create reproducible isolated case.
I can not at this moment attach the exact file. In short you need to create a file you use as a user library assets file, create an asset and try to assign a custom thumbnail to it in asset browser. You get the crash report (crashes with different stacks for other files and when editing):
Translated Report (Full Report Below)
Process:               Blender [3785]
Path:                  /Applications/Blender.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               3.0.0 (3.0.0 2021-12-03)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-01-08 18:51:36.0639 +0100
OS Version:            macOS 12.1 (21C52)
Report Version:        12
Bridge OS Version:     6.1 (19P647)
Anonymous UUID:        BAF76297-0E65-F3CC-0672-23E0B08EE74B
Sleep/Wake UUID:       041C4EFB-CD61-441A-A0ED-258E95742A70
Time Awake Since Boot: 70000 seconds
Time Since Wake:       28576 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGSEGV)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   Blender [3785]
Thread 0 Crashed:
0   libsystem_kernel.dylib        	    0x7ff81e793af6 semaphore_wait_trap + 10
1   libdispatch.dylib             	    0x7ff81e61a178 _dispatch_sema4_wait + 16
2   libdispatch.dylib             	    0x7ff81e61a647 _dispatch_semaphore_wait_slow + 98
3   Blender                       	       0x10de4e26f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
4   Blender                       	       0x10de4ccfe void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
5   libsystem_pthread.dylib       	    0x7ff81e7d04f4 _pthread_start + 125
6   libsystem_pthread.dylib       	    0x7ff81e7cc00f thread_start + 15
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
0   libsystem_pthread.dylib       	    0x7ff81e7cbfec start_wqthread + 0
Thread 13::  Dispatch queue: com.Metal.CommandQueueDispatch
3   Metal                         	    0x7ff827122f8d -[_MTLCommandQueue _submitAvailableCommandBuffers] + 922
4   libdispatch.dylib             	    0x7ff81e619cc9 _dispatch_client_callout + 8
5   libdispatch.dylib             	    0x7ff81e61c746 _dispatch_continuation_pop + 460
6   libdispatch.dylib             	    0x7ff81e62da5a _dispatch_source_invoke + 2150
7   libdispatch.dylib             	    0x7ff81e61fb85 _dispatch_lane_serial_drain + 335
8   libdispatch.dylib             	    0x7ff81e6207c8 _dispatch_lane_invoke + 366
9   libdispatch.dylib             	    0x7ff81e62a7e1 _dispatch_workloop_worker_thread + 758
10  libsystem_pthread.dylib       	    0x7ff81e7cd074 _pthread_wqthread + 326
11  libsystem_pthread.dylib       	    0x7ff81e7cbffb start_wqthread + 15
Thread 14:: AMCP Logging Spool
1   caulk                         	    0x7ff8272541c0 caulk::mach::semaphore::wait_or_error() + 16
2   caulk                         	    0x7ff82723b08a caulk::concurrent::details::worker_thread::run() + 36
3   caulk                         	    0x7ff82723ad4e void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
4   libsystem_pthread.dylib       	    0x7ff81e7d04f4 _pthread_start + 125
5   libsystem_pthread.dylib       	    0x7ff81e7cc00f thread_start + 15
Thread 15:
Thread 16:
Thread 17:
Thread 18:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	    0x7ff81e793aba mach_msg_trap + 10
1   libsystem_kernel.dylib        	    0x7ff81e793e2b mach_msg + 59
2   CoreAudio                     	    0x7ff82041795b HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3   CoreAudio                     	    0x7ff8202a60ff HALC_ProxyIOContext::IOWorkLoop() + 3937
4   CoreAudio                     	    0x7ff8202a4bc1 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63
5   CoreAudio                     	    0x7ff82046d76c HALB_IOThread::Entry(void*) + 72
6   libsystem_pthread.dylib       	    0x7ff81e7d04f4 _pthread_start + 125
7   libsystem_pthread.dylib       	    0x7ff81e7cc00f thread_start + 15
Thread 19:
1   Blender                       	       0x10620e378 tbb::internal::rml::private_worker::run() + 344
2   Blender                       	       0x10620e219 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3   libsystem_pthread.dylib       	    0x7ff81e7d04f4 _pthread_start + 125
4   libsystem_pthread.dylib       	    0x7ff81e7cc00f thread_start + 15
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:: com.apple.NSEventThread
2   CoreFoundation                	    0x7ff81e897af2 __CFRunLoopServiceMachPort + 319
3   CoreFoundation                	    0x7ff81e8961cb __CFRunLoopRun + 1325
4   CoreFoundation                	    0x7ff81e8955dd CFRunLoopRunSpecific + 563
5   AppKit                        	    0x7ff821432d98 _NSEventThread + 132
Thread 31:
Thread 32:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x000000000000000e  rbx: 0x00007fab378478b0  rcx: 0x0000700009822f08  rdx: 0x0000000000000000
  rdi: 0x0000000000002503  rsi: 0xffffffffffffffff  rbp: 0x0000700009822f20  rsp: 0x0000700009822f08
   r8: 0x00007ff85fffbff0   r9: 0xffffffff00000000  r10: 0x00000001126764d8  r11: 0x0000000000000246
  r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x00007fab378478b0  r15: 0xffffffffffffffff
  rip: 0x00007ff81e793af6  rfl: 0x0000000000000246  cr2: 0x0000700009928ff8
Logical CPU:     0
Error Code:      0x01000024
Trap Number:     133
Binary Images:
    0x7ff81e793000 -     0x7ff81e7c9fff libsystem_kernel.dylib (*) <5aa1e5be-b5b8-3a02-9885-a8c99e0ca378> /usr/lib/system/libsystem_kernel.dylib
    0x7ff81e617000 -     0x7ff81e65dfff libdispatch.dylib (*) <c8f7bfb6-4b1a-37cd-a32d-cd5069c916df> /usr/lib/system/libdispatch.dylib
       0x105b09000 -        0x112104fff org.blenderfoundation.blender (3.0.0) <8acf8f8a-1a0b-37b4-a45b-75aaca58c182> /Applications/Blender.app/Contents/MacOS/Blender
    0x7ff81e7ca000 -     0x7ff81e7d5fff libsystem_pthread.dylib (*) <6c7561b4-4b92-3f45-921e-abe669299844> /usr/lib/system/libsystem_pthread.dylib
    0x7ff827102000 -     0x7ff827238fff com.apple.Metal (258.17) <8977ee5c-d994-339a-b1f7-46efa1772794> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7ff827239000 -     0x7ff82725bfff com.apple.audio.caulk (1.0) <e76d1ab3-89c2-3a93-990b-30827fcf89b0> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7ff8200ef000 -     0x7ff820816fff com.apple.audio.CoreAudio (5.0) <33f55d9c-eaef-3fbd-add5-ed3e54925762> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7ff81e817000 -     0x7ff81ed19fff com.apple.CoreFoundation (6.9) <eab0e216-2a9e-31ce-9164-fdf3ebcf7bd3> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff821286000 -     0x7ff822114fff com.apple.AppKit (6.9) <d23b9681-3764-3298-a716-fbb511dd5a7c> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)
Writable regions: Total=539.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=539.5M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               256K        2
Activity Tracing                   256K        1
CG backing stores                 2688K        4
CG image                           100K        6
ColorSync                          224K       25
CoreAnimation                      176K       13
CoreGraphics                        12K        2
CoreImage                            4K        1
CoreUI image data                 1080K        8
Dispatch continuations            96.0M        1
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                           254.2M       84
MALLOC guard page                   48K       10
MALLOC_MEDIUM (reserved)          72.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        256K        3
STACK GUARD                        132K       33
Stack                             56.3M       35
Stack Guard                          4K        1
VM_ALLOCATE                       44.0M      244
VM_ALLOCATE (reserved)              32K        1         reserved VM address space (unallocated)
__DATA                            98.7M      350
__DATA_CONST                      17.1M      207
__DATA_DIRTY                       774K      118
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       698.8M       17
__OBJC_RO                         81.8M        1
__OBJC_RW                         3136K        2
__TEXT                           481.0M      363
__UNICODE                          588K        1
dyld private memory               1088K        3
mapped file                      164.0M       27
shared memory                      784K       18
TOTAL                              2.0G     1586
TOTAL, minus reserved VM space     2.0G     1586
Full Report
{"app_name":"Blender","timestamp":"2022-01-08 18:51:36.00 +0100","app_version":"3.0.0","slice_uuid":"8acf8f8a-1a0b-37b4-a45b-75aaca58c182","build_version":"3.0.0 2021-12-03","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.1 (21C52)","incident_id":"C85674EE-9A3E-42B4-A232-06012036C90B","name":"Blender"}
  "uptime" : 70000,
  "procLaunch" : "2022-01-08 18:51:08.8392 +0100",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro16,1",
  "procStartAbsTime" : 70720417224609,
  "coalitionID" : 540,
  "osVersion" : {
    "train" : "macOS 12.1",
    "build" : "21C52",
    "releaseType" : "User"
  "captureTime" : "2022-01-08 18:51:36.0639 +0100",
  "incident" : "C85674EE-9A3E-42B4-A232-06012036C90B",
  "bug_type" : "309",
  "pid" : 3785,
  "procExitAbsTime" : 70747622240136,
  "cpuType" : "X86-64",
  "procName" : "Blender",
  "procPath" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
  "bundleInfo" : {"CFBundleShortVersionString":"3.0.0","CFBundleVersion":"3.0.0 2021-12-03","CFBundleIdentifier":"org.blenderfoundation.blender"},
  "storeInfo" : {"deviceIdentifierForVendor":"39CB2ACC-1148-5821-AB90-8D6F120CC508","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "org.blenderfoundation.blender",
  "crashReporterKey" : "BAF76297-0E65-F3CC-0672-23E0B08EE74B",
  "wakeTime" : 28576,
  "bridgeVersion" : {"build":"19P647","train":"6.1"},
  "sleepWakeUUID" : "041C4EFB-CD61-441A-A0ED-258E95742A70",
  "sip" : "enabled",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGSEGV"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"Blender","byPid":3785},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":2987672,"threadState":{"r13":{"value":0},"rax":{"value":14},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":140373347563696},"rsi":{"value":18446744073709551615},"r8":{"value":140704739213296,"symbolLocation":0,"symbol":"_pthread_keys"},"cr2":{"value":123145462910968},"rdx":{"value":0},"r10":{"value":4603733208,"symbolLocation":16,"symbol":"vtable for IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread"},"r9":{"value":18446744069414584320},"r15":{"value":18446744073709551615},"rbx":{"value":140373347563696},"trap":{"value":133},"err":{"value":16777252},"r11":{"value":582},"rip":{"value":140703639878390,"matchesCrashFrame":1},"rbp":{"value":123145461837600},"rsp":{"value":123145461837576},"r12":{"value":0},"rcx":{"value":123145461837576},"flavor":"x86_THREAD_STATE","rdi":{"value":9475}},"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987673,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987674,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987675,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987676,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987677,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987678,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987679,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987680,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987681,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987682,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987683,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":137646703,"symbol":"IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":79,"imageIndex":2},{"imageOffset":137641214,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*)","symbolLocation":62,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987685,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":2987686,"queue":"com.Metal.CommandQueueDispatch","frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":12664,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":1},{"imageOffset":13895,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":1},{"imageOffset":135053,"symbol":"-[_MTLCommandQueue _submitAvailableCommandBuffers]","symbolLocation":922,"imageIndex":4},{"imageOffset":11465,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":1},{"imageOffset":22342,"symbol":"_dispatch_continuation_pop","symbolLocation":460,"imageIndex":1},{"imageOffset":92762,"symbol":"_dispatch_source_invoke","symbolLocation":2150,"imageIndex":1},{"imageOffset":35717,"symbol":"_dispatch_lane_serial_drain","symbolLocation":335,"imageIndex":1},{"imageOffset":38856,"symbol":"_dispatch_lane_invoke","symbolLocation":366,"imageIndex":1},{"imageOffset":79841,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":758,"imageIndex":1},{"imageOffset":12404,"symbol":"_pthread_wqthread","symbolLocation":326,"imageIndex":3},{"imageOffset":8187,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":3}]},{"id":2987687,"name":"AMCP Logging Spool","frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":111040,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":5},{"imageOffset":8330,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":5},{"imageOffset":7502,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":5},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987722,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":2987726,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":2987727,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":2987729,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":3311963,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":6},{"imageOffset":1798399,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":3937,"imageIndex":6},{"imageOffset":1792961,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":63,"imageIndex":6},{"imageOffset":3663724,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":6},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987787,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987788,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987789,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987790,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987791,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987792,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987793,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987794,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987795,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987796,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987797,"frames":[{"imageOffset":2806,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":7361400,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":344,"imageIndex":2},{"imageOffset":7361049,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":2},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2987901,"name":"com.apple.NSEventThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":0},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":0},{"imageOffset":527090,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":7},{"imageOffset":520651,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":7},{"imageOffset":517597,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":7},{"imageOffset":1756568,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":8},{"imageOffset":25844,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":3},{"imageOffset":8207,"symbol":"thread_start","symbolLocation":15,"imageIndex":3}]},{"id":2989081,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]},{"id":2989151,"frames":[{"imageOffset":8172,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":3}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703639875584,
    "size" : 225280,
    "uuid" : "5aa1e5be-b5b8-3a02-9885-a8c99e0ca378",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703638319104,
    "size" : 290816,
    "uuid" : "c8f7bfb6-4b1a-37cd-a32d-cd5069c916df",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4390424576,
    "CFBundleShortVersionString" : "3.0.0",
    "CFBundleIdentifier" : "org.blenderfoundation.blender",
    "size" : 207601664,
    "uuid" : "8acf8f8a-1a0b-37b4-a45b-75aaca58c182",
    "path" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
    "name" : "Blender",
    "CFBundleVersion" : "3.0.0 2021-12-03"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703640100864,
    "size" : 49152,
    "uuid" : "6c7561b4-4b92-3f45-921e-abe669299844",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703783985152,
    "CFBundleShortVersionString" : "258.17",
    "CFBundleIdentifier" : "com.apple.Metal",
    "size" : 1273856,
    "uuid" : "8977ee5c-d994-339a-b1f7-46efa1772794",
    "path" : "\/System\/Library\/Frameworks\/Metal.framework\/Versions\/A\/Metal",
    "name" : "Metal",
    "CFBundleVersion" : "258.17"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703785259008,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 143360,
    "uuid" : "e76d1ab3-89c2-3a93-990b-30827fcf89b0",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703666466816,
    "CFBundleShortVersionString" : "5.0",
    "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
    "size" : 7503872,
    "uuid" : "33f55d9c-eaef-3fbd-add5-ed3e54925762",
    "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
    "name" : "CoreAudio",
    "CFBundleVersion" : "5.0"
    "source" : "P",
    "arch" : "x86_64h",
    "base" : 140703640416256,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5255168,
    "uuid" : "eab0e216-2a9e-31ce-9164-fdf3ebcf7bd3",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1856.105"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703684911104,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15265792,
    "uuid" : "d23b9681-3764-3298-a716-fbb511dd5a7c",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.20.111"
  "sharedCache" : {
  "base" : 140703636873216,
  "size" : 15216738304,
  "uuid" : "40432a03-88d3-305f-9c0c-e7549e71d927"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)\nWritable regions: Total=539.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=539.5M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               256K        2 \nActivity Tracing                   256K        1 \nCG backing stores                 2688K        4 \nCG image                           100K        6 \nColorSync                          224K       25 \nCoreAnimation                      176K       13 \nCoreGraphics                        12K        2 \nCoreImage                            4K        1 \nCoreUI image data                 1080K        8 \nDispatch continuations            96.0M        1 \nFoundation                          16K        1 \nKernel Alloc Once                    8K        1 \nMALLOC                           254.2M       84 \nMALLOC guard page                   48K       10 \nMALLOC_MEDIUM (reserved)          72.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nSTACK GUARD                        132K       33 \nStack                             56.3M       35 \nStack Guard                          4K        1 \nVM_ALLOCATE                       44.0M      244 \nVM_ALLOCATE (reserved)              32K        1         reserved VM address space (unallocated)\n__DATA                            98.7M      350 \n__DATA_CONST                      17.1M      207 \n__DATA_DIRTY                       774K      118 \n__FONT_DATA                          4K        1 \n__GLSLBUILTINS                    5176K        1 \n__LINKEDIT                       698.8M       17 \n__OBJC_RO                         81.8M        1 \n__OBJC_RW                         3136K        2 \n__TEXT                           481.0M      363 \n__UNICODE                          588K        1 \ndyld private memory               1088K        3 \nmapped file                      164.0M       27 \nshared memory                      784K       18 \n===========                     =======  ======= \nTOTAL                              2.0G     1586 \nTOTAL, minus reserved VM space     2.0G     1586 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "607844aa04477260f58a8077",
      "factorPackIds" : {
        "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
      "deploymentId" : 240000066
      "rolloutId" : "5ffde50ce2aacd000d47a95f",
      "factorPackIds" : {
      "deploymentId" : 240000090
      "rolloutId" : "602ad4dac86151000cf27e46",
      "factorPackIds" : {
        "SIRI_DICTATION_ASSETS" : "6193d03f2171a2330e561dfc"
      "deploymentId" : 240000290
      "rolloutId" : "60da5e84ab0ca017dace9abf",
      "factorPackIds" : {
      "deploymentId" : 240000008
      "rolloutId" : "601d9415f79519000ccd4b69",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "61c11dcd2cb6041dc630dc63"
      "deploymentId" : 240000357
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 240000196
  "experiments" : [
Model: MacBookPro16,1, BootROM 1715.60.5.0.0 (iBridge: 19.16.10647.0.0,0), 6 processors, 6-Core Intel Core i7, 2,6 GHz, 32 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Graphics: AMD Radeon Pro 5300M, AMD Radeon Pro 5300M, PCIe, 4 GB
Display: Color LCD, 3072 x 1920 Retina, Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2667 MHz, Micron, MT40A2G8NEA-062E:J
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2667 MHz, Micron, MT40A2G8NEA-062E:J
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 18:02:56 version 9.30.464.0.32.5.76 FWID 01-c081cfed
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: T2Bus
USB Device: composite_device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 63.5
Bohdan Tsymbala (efreeti) created this task.Jan 8 2022, 7:04 PM
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jan 8 2022, 7:12 PM
Pratik Borhade (PratikPB2123) edited projects, added BF Blender; removed Blender Asset Bundle.
Pratik Borhade (PratikPB2123) added a subscriber: Pratik Borhade (PratikPB2123).
Hi, thanks for the report. This got fixed already, see: T93691: Crash when trying to load custom preview in asset browser with user library selected
Can you please check again with recent 3.1.0 build?: https://builder.blender.org/download/daily
Pratik Borhade (PratikPB2123) updated the task description.Jan 8 2022, 7:13 PM
Pratik Borhade (PratikPB2123) changed the subtype of this task from "Design" to "Report".
Pratik Borhade (PratikPB2123) closed this task as Archived.Jan 18 2022, 8:25 AM
