Maniphest T94757
Disable in Viewports: when turned off, the f-Curve is also off
Closed, Duplicate
None
Piero (phoenixart)
Jan 9 2022, 2:03 AM
  • BF Blender
Germano Cavalcante (mano-wii)
Piero (phoenixart)
Graphics card: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.84
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
When animating "Disable in Viewport" from on to off, it also turns off all the other animated properties in the f-curve, and the dope sheet window.
Maybe it's by design, but it looks a bug to me, as I can't tweak the other animated parameters of the selected object if the viewports visibility is off.
Piero (phoenixart) created this task.Jan 9 2022, 2:03 AM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Jan 11 2022, 6:48 PM
Thanks for the report, but could you provide a simple .blend file showing the problem, so it will be easier to understand what you are referring to.
A guideline for making a bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Piero (phoenixart) added a comment.Jan 12 2022, 12:46 AM
Sure, here's a basic scene{F12801677}.
Germano Cavalcante (mano-wii) added a comment.Jan 12 2022, 4:42 PM
You can tweak the filters to get around the problem:
But the fact that the F-Curve of a selected object disappears when an object is hidden, is a known issue, as hidden objects cannot be selected.
This has already been reported in T71335: Animating hide_viewport propertie deselect objects
Germano Cavalcante (mano-wii) closed this task as a duplicate of T71335: Animating hide_viewport propertie deselect objects.Jan 12 2022, 4:42 PM
